Cracked Keel 1999 starcraft 2290
Discussion in 'Boatbuilding' started by Ra3ei Ba7er, Sep 22, 2011.
  1. Ra3ei Ba7er
    Likes: 3, Points: 0, Legacy Rep: 26
    Ra3ei Ba7er Junior Member
    More pictures
  2. tunnels
    tunnels Previous Member
    The joys of building boats and seeing other peoples handi work !!
    Yes i did notice those bubbles and little pockets of air in the resin and glass this also is not uncommon!
    When the guy guns the glass they usually run a extra couple of passes with a gun to give a little bit of thickeness so when the woven roving goes into the strake it will sit better ho ho . 99% of the time the roller they would have used is the wrong size and theres glass and resin and air trapped there and never gets rolled out properly .all done for speed . no care and little attention to detail .
    In recent years i carry my camera with me a good part of the time no matter where i am working or what im doing . Have hundreds of pictures for all occassions and each week i collect even more . While working in Korea i keep a photographic diary so to speak of things and happeings each day for all the time i was there . after they realised what i was doing things really improved all round . Making people aware and making them responsable and you cant argue with a picture of what they had been doing !!.
    On the computer i can enhance and change light and colours etc to make things change so they are clearer and easyer to see .:D
  3. Ra3ei Ba7er
    Hi
    I started with the painting process, but my staff as I told you are Auto painters, they are very good with cars but as told you earlier ZERO marine experience.
    I do not want to do poor and wrong paint job, I want to do a professional marine gelcoat finishing.
    My idea is to make the surface fair and smooth, then apply (talc+resin) as putty compound and filler, then sand it then spray gelcoat.
    Is it correct way?
    If so then my question, how to spray/apply gelcoat to get a marine quality finishing that looks professional and last long as new boat.
    waiting for reply with details of tools/ material needed.
  4. tunnels
    SAND AND APPLY YOUR STANDARD AUTOMOTIVE FILLERS FROM THE TIN WITH A HARDENER !! THEY ARE MADE FROM POLYESTER RESINS ANYWAY AND ITS WHAT IVE ALWAYS USED FOR YEARS . LONG BOARD IT FLAT AND USE A GOOD 2 PART POLY URETHANE TOP COAT TO FINISH IT WITH . jUST TREAT IT LIKE A CAR TO FINISH !
    ALWAYS USE 2 PART PAINTS WHERE EVER POSSIBLE BECAUSE THEY ARE HARDER WEARING AND BETTER UV PROTECTED . :D:p
  5. Ra3ei Ba7er
    These are pictures of today painting process which I stopped.
    The last 2 pictures of the stracke done by my staff it look super with Car paint system, However I did paint the same boat earlier with the same method and material.
  6. Ra3ei Ba7er
    I will do the painting later, tomorrow we will do the foam filling inside the boat and correct the fuel tank partitions , this way we give more time for the fiber glass on the stracke outside under the hull to fully dry.
  7. Ra3ei Ba7er
    Today we filled foam in the stringer molde, we are getting closer to finish this project.
    See the pictures
  8. tunnels
    Hello
    Have missed you !! Hows progress ?? what stage are you at ?? in the water yet or cant find the water ??:confused:
  9. Ra3ei Ba7er
    hi
    We are painting stage and also redoing electicals
    maybe another week
  10. tunnels
    Thank you ! I was just wondering what was happening thats all . :D
  11. Ra3ei Ba7er
    I very much value your follow-up
  12. tunnels
    People on this site spend hours helping sometimes and we all follow and most time never see or hear the end results .
    I like to just keep intouch . I am a kiwi living in china !! so hands across the water so to speak . Good luck ! :D
  13. Ra3ei Ba7er
    I will keep on posting until i put the boat again in the water, also I will keep on reading other posts and share my experince with
  14. Ra3ei Ba7er
    I will post tomorrow smothing the stracks as the original molded by my Auto denter, then painting it
  15. Ra3ei Ba7er
    todays cosmatical work
