Covering Boards
Discussion in 'Boatbuilding' started by oceansswk, Sep 28, 2022.
Tags:
  1. oceansswk
    oceansswk Junior Member
    I am removing teak covering boards and do not plan on replacing them. I would like to add a layer of 1/2 or 3/4' divinycell H80 as the replacement. Would you recommend that material and how would you laminate it to the existing gunnels?
    Thank you
    John
  2. Rumars
    Likes: 1,034, Points: 113, Legacy Rep: 39
    Rumars Senior Member
    That depends entirely on how your hull and deck are buildt. Coverboards exist to provide rim strength so the deck can be caulked. If you have a subdeck then they are purely cosmetic and the question becomes what's it made of.
    Without more details it's impossible to give you a meaningful answer.
  3. oceansswk
    The teak is strictly cosmetic. I like the raised look of teak on the gunnels. So I figured I could glass divinycell approx. 3/4" thick to existing fiberglass. Not sure how to attach and cover it.
    Thanks
  4. rangebowdrie
    Likes: 83, Points: 28, Legacy Rep: 10
    rangebowdrie Senior Member
    Heresy!
    Replace Teak with 5lb density plastic foam?:(:eek:
    No boat for you, back to the farm with you. ;)
  5. Rumars
    Remove teak, sand the fiberglass clean, glue on foam (thickened polyester or epoxy), glass over as much as you like, fill, sand and paint.
  6. kapnD
    Likes: 383, Points: 83, Legacy Rep: 40
    kapnD Senior Member
