Could you build a boat like this?
Discussion in 'Boatbuilding' started by stonedpirate, Nov 28, 2009.
  1. stonedpirate
    Likes: 3, Points: 0, Legacy Rep: 23
    stonedpirate Senior Member
    Hello,
    I dont have a clue about wood and was wondering if the following is a valid building technique.
    You know how you have the keel then put on some ribs then fill in the rest with planks. What if you just made heaps of ribs and screwed them together?
    Sorry, not sure how to explain it.
    Imagine having a finished yacht, then cutting it into strips like a CAT scan.
    ....\___________________________/
    Each one of thos "|" is a rib screwed onto the one next to it.
    So you could make each rib slightly smaller or bigger than the next one and when they are all screwed together, it would look blocky then you could sand it back smooth.
    lol, i'm not sure how else to explain it.
    Thanks to anyone that took the time to try understand that :p
    Cheers
  2. boat fan
    Likes: 17, Points: 18, Legacy Rep: 435
    boat fan Senior Member
    Sure ...could be done.
    If you built in wood ,the sand paper would cost more than the boat though.....
    and you would never want to sand ANYTHING again before you were half way done .....:D
    The real question should perhaps be : Why ?
    Slow , hard way to build a boat.
    Much better ways being used.....
    Your original question : Is it a valid building technique ?
    No.
  3. masalai
    masalai masalai
    Why?
    What advantage is there?
    Where
    When
    How big
    Are you a mad-inventor techie?
    Are you familiar with laser-polymer-hardening-techniques?
    Have you access to significant computing power and associated technology?
  4. stonedpirate
    Because the boat is only 8 foot so it wouldnt need many ribs.
    And figured that it would be stronger because the ribs a thicker, dont have to use ply wood or steam to get a curved shape because you can cut the ribs curved from flat wood and it would be solid as a tank.
    My only problem with it is that i dont know much about wood and was wondering if the individual ribs would absorb water and it would all buckle and leak.
    Maybe, but you could use a power snader and make the ribs so they arent that much bigger or smaller than the next.
    Is there any substance you could apply to the finished hull on the outside to avoid sanding and bring it out smooth?
    Like tar or something, put it on think and smooth and you wouldnt see the knotches from each rib.
    Man i suck at dscribing things :p
    Need a woodworking vocabulary :p
  5. TeddyDiver
    Likes: 136, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    The real problem with your method lies in the directional strength. Can you quess which way it's worse?
  6. stonedpirate
    No, not sure what you mean.
    I am assuming the grain of the wood would make it weak from the sides.
    Just thought a thick rib made of oak would be stronger than ply between ribs.
  7. boat fan
    Teddy answered the strength issue.
    You will be well advised to believe him.
    Power planer can only be used on flat or convex surfaces .
    What shape boat ?
    If its only 8 ft do yourself a favour and build Stitch and Glue.
    Fast , easy , cheap , good.
  8. stonedpirate
    Stitch and glue is good for rivers and estuaries, I need the most solid and strongest bluewater 8 foot wooden hull in existence :p
  9. boat fan
    How many boats have you seen built this way ( in any size ).
    That should answer the " why " question.
  10. boat fan
    Are you kidding?
    S&G ....laminate another layer if you must ....
    You are kidding us aren`t you ?
    S& G is good for anywhere.
  11. stonedpirate
    I know nothing about wood or boat building so thought that it may have been a valid technique.
    When i seen the keel and rib frames, my first thought was why not fill the gaps between ribs with more ribs so thought it might be doable.
  12. TeddyDiver
    Doable, yes but with the planking you omit gives the longitudinal strength. To get as much longitudunal strengt with this "ribs only" method you need smth like three to five times more thickness for you hull..
  13. stonedpirate
    Ahhh, i see.
    Thanks for explaining that to me :)
  14. stonedpirate
    I want to build something like this and as tough as possible:
  15. stonedpirate
    But round with a full keel like a traditional yacht in minature.
