Ti takes a lot of energy and specialize process to make.
it does suffer dissimilar metal issues, but usally assembly is with sealants as well as painted surfaces.
Ti, though corrosion resistant, is highly reactive to common materials, salts, cad plated fasteners, etc. You get inter-granular corrosion tracks at the microscopic level, which is usually discovered after the part suddenly fails without warning (usually catastrophically). Bolt heads just pop off suddenly, cast fittings pop apart while sitting on a shelf, no loads on it at all.
When I once worked for the little local aircraft manufacturer over twenty years ago, I had to write a service bulletin to replace the large cad plated bolts holding the Ti alloy engine mounts to the underside of the wing. A number of commercial aircraft were delivered with cad plated bolts in the Ti fittings, they had to all be replaced (which means defueling the wings to get access to the bolt heads from inside the fuel tanks), removing the six 1" dia high strength bolts, removing the engine mounts fittings and sending them to a metallurgy lab to test the fittings for cadinum embrittlement of the alloy (there is no field test for that problem). If they had cad embrittlement present, the costly parts had to be scraped, there was no way of salvaging them. something like 22 aircraft were effected, four engines each aircraft, four fittings per engine, six bolts per fitting. It was a very costly assembly mistake. The company learned about the assembly error when an operator reported a failed engine mount, which occurred while the aircraft was parked, engine off (it just "popped" off while sitting still, engine hanging off at an odd angle held up by the wire bundles and the hydraulic lines). An investigation found that the painted bolts specified were not available during the production run and a supply agent substituted the cad plated bolts, which were structurally identical (and normally a good substitute), but a tiny foot note on the massive wing assembly drawing was overlooked that stated "no substitute", and no explanation as to why. They met their production dead line, but unwittingly created a very serious safety hazard in the process.
I am not sure how this kind of problem would play out in a boat subject to a rather harsh chemical environment and not nearly the kind of carefully supervised assembly and maintenance as compared to aircraft (where all the suppliers, mechanics, and supervisors, and inspectors, have to be certified for anything on a commercial aircraft).
some kind of industrial grade Ti might be a solution, if the intergranular corrosion and contamination issues can be worked out. but it might be that Ti of that quality may offer no advantages over much less costly and well known aluminum alloys for marine applications.
Titanium is not quite the "magic" material everyone thinks it is. Not just costly, but has some very practical limitations and down sides.
