Coosa alternatives
comfisherman
Senior Member
Joined
Apr 26, 2009
Messages
1,027
Reaction score
561
Location
Alaska
Anyone use the Coosa alternatives? My supplier is about 4x farther out on Coosa than an offbrand equivalent, anyone have any experience with any of the blue water 20 and 26 clones? Think it's got some goofy name like "space age" or some such deal.
Normally like to just use the original innovators but weeks vs. Months would be nice.
Used corelite board and aquaplas. Get it heavy enough density for the work planned.
Interesting, I'll look up the core lite and see how hard it's to get on this coast.
Initially I was referring to direct clones to Coosa, but any direct ply replacement would do.
My understanding is Coosa and the offbrands are all made from the same base material. There was some kind of plant problem and production was halted for some time. I waited over 3 months for two sheets of 3/4" 26. They are taking care of the big customers first.
Express Composites in Minneapolis may have some. If you want cheaper shipping; not sure if they will cut.
In the volume I'd need it's gonna be ltl no matter what. I'll give them a look, the parent company website was fairly vague but left a message with them anyway.
Yup they had an issue in early 21, lead times improved but are still running a bit over 3 months. Have a fellow who wants a deck and aft bulkhead done like I did on my last boat, we used 25 or 30 sheets all in total and my boat is smaller than his. We have such a short window between the end of the season and cold I'm concerned a Coosa delay of just a few weeks could scupper the project.
Hire a NA to run some calculations on whatever foam core is in stock. You will end up with a thicker skin then on coosa, but it's often cheaper overall if you don't pay for the labor.
Eh... our projects make a naval architects eye twitch... but not many architects understand a sleep deprived crewman bouncing 6xs off the deck.
No need to understand much, you supply the laminate schedule for coosa and ask for same properties using another foam.
Tried a bit today chasing down corelite, no Mas. So going to have an outfit ship a Coosa clone from an offbrand to test.
Figure I'd do a self follow up on corelite.
It's currently available in 3/4 inch only, no stocking distribution outside Florida and east Canada. Minimum order is 5 sheets from the Florida distribution center. Kinda a lot to order to test a segment.
All in I'll probably stick with Coosa as the cost difference per sheet Wil only be a few thousand saved on a six figure project, as wel my Coosa pimp says the last order was 4-5 weeks from order to delivery. Maybe next time I'm in FL I'll find a chunk to put through its paces.
On the upside the company sells some high density foams that look like good replacements for h-120.
