Cooling of engine
Discussion in 'Propulsion' started by Ove, Sep 17, 2011.
  1. Ove
    Ove New Member
    Hi...
    I am looking for a formula to calculate how much pipe I will need to remove a certain amount of KW in an outboard cooler.
    Known data is how many KW I need to cool.
    The water temperature.
    Water flow in the cooling pipes.
    Dimension of cooling pipes (outer diam. and wall thickness) and I nee dto calculate how many meter of a given pipe I will need to cool the given effect.
    Can somebody help me with a formula for this ?
    Thanks.....
  2. TeddyDiver
    Likes: 146, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    A quote from old thread..
    A quote in a quote in a quote... :D
    and the original thread in case you might enjoy how to bend it so to speek..
    http://www.boatdesign.net/forums/diesel-engines/kool-keel-diesel-engine-34858.html
  3. Ove
    Ove New Member
    Keel cooling calculations
    Thanks, but I was more looking after a way to calculate the heat transmission in a keel cooler. I also have a number of experience figures but I wish to calculate it with the real figures of heat needed to be cooled, water temperature, waterflow, dimension of pipes, wall thickness etc.
    If any one can help me I would be grateful....
    Regards
    Ove
  4. MikeJohns
    MikeJohns Senior Member
  5. CDK
    CDK retired engineer
    Ove, there is no formula because there are too many variables.
    What you want to know is the thermal efficiency, expressed as delta t/ kW, for a heavily painted, barnacle festered keel cooler in a motionless sea. I'm afraid nobody can tell you that.
    But you could use TeddyDiver's data as a starting point. 6 m2 for 100 hp translates to 0.08 m2 for 1 kW. That is approx. 1 meter of 1 inch steel pipe for every kW of the engine rating.
  6. pistnbroke
    Likes: 35, Points: 48, Legacy Rep: 404
    pistnbroke I try
    and why would you want to do this on an outboard? if its that nasty impeller you dont like why not an external pump ? I can see how you can get the water into the outboard but how are you to stop it mixing with the exhaust ?
  7. Mr Efficiency
    I think he means outboard as in 'external', not an outboard motor.
  8. pistnbroke
    pistnbroke I try
    Yes I miss read it ..its the cooler that is outboard not an outboard cooler Dooh .....
