Seafarer24
Sunset Chaser
- Joined
- May 11, 2005
- Messages
- 228
- Reaction score
- Location
- Tampa Bay
I might be helping a gentleman go this route after he lost his keel-stepped mast. I believe there is still a stub left, and there is a mast of approximately the correct proportions available, but it is deck-stepped.
My proposition is this: Cut the keel-stepped stub even with the deck. Fabricate an aluminum plate with a bottom section that will slip into this stub and be welded to it, and a top section that will act as the step for the deck-stepped mast. The plate would protrude horizontally enough to support a ring of bolts through the deck to support it laterally. In this fashion, the original mast becomes a compression post for the new mast.
Are there any flaws to this idea?
