Converting a Rowboat to a sailing dinghy
Leeboard or Centerboard? Or both?
  • Only Leeboards
    Votes: 1 50.0%
  • Only Centerboard
    Votes: 0 0.0%
  • Both
    Votes: 1 50.0%
  • Total voters
    2
Oscar1
Junior Member
Joined
Aug 21, 2024
Messages
6
Reaction score
Location
Denmark
Hello,
i just bought a 10 ft /3 m dinghy that was used for rowing before. It is made of glasfiber. It has a beam of 140 cm and a height of 40 cm. It has no centerboard or keel and i think it weighs around 100-200kg.
I want to convert it to a sailing dinghy that could sail in light wind near in coastal regions.
I was thinking about using leeboards as opposed to installing a centerboard/daggerboard, however im unsure if that would even provide any sort of stability. I would like to only use leeboards as if i can avoid cutting a hole in the boat for the centerboard would be nice. However i will still have to repair some small holes with glasfiber and epoxy or polyester.
Any response would be appreciated as i am kind of conflicted about how to continue on this.
Also tips or recomndations on what to do about other things i haven't thought of would be nice.
Best regards Oscar :D
I will send pictures soon.
For a small boat it is best to forget about the notion of any kind of board adding stability.The need is for some kind of surface(s) to resist leeway and whatever choice is made will need to built sufficiently strong to resist the force that the rig is capable of generating.Without knowing what kind of boatbuilding experience can be applied to the project it is difficult to make precise recommendations.Pictures may be useful
Hi Oscar1, keep the rowing aspect workable, and look at a balanced lug sail rig, which is very simple and easily installed in most cases. Lee boards will be OK, you can use one on a tether, swapping sides after tacking. 100 - 200 Kg is very heavy for a dinghy and it won't be fast, but its weight, and a lee board should give it some stability. On my dinghy I made 2 supports at stern and front deck to hold the mast, boom, and yard overhead while rowing, to get under low bridges, and make way in calms. Look for second hand rudder, mast, and boom from eg. a Mirror dinghy or Heron dinghy, or similar 10 - 12 foot long sailing dinghy. You may even adapt a complete rig and sail setup, except for complications arising from using lee boards. Don't spend any big money, do it cheap, and have fun. Make your trailer as easy to launch and retrieve as possible so you don't ruin your back with such a heavy boat.
Hello, i sent pictures in the thread, Thanks for your response, i dont have any boat building experince really, im just currently reading a lot of books and doing online research on the matter. I also intend to do some stability calculations before i add the rig.
Thanks for your response, i will certainly look into lug sails, i am also trying to get most of the stuff second hand. I might look into keeping the rowing part aswell, i also thought about using a Yuloh oar for sculling or something as not to have big oars taking up too much space. I also sent pictures in thread if you want to have a look, i will most likely give it a new layer of paint on bottom. I worry a bit about it capsizing though due to the fact it is quite flat on the bottom, however i will have to test in safe waters. Thanks.
That is not a rowboat, but a poweboat. It will be a terrible sailboat. The wide stern and flat buttocks are designed to plane.
I wouldn't recommend getting too bogged down in stability calculations,other than as an exercise.For most dinghies there is an easy remedy in the muscles of the sailor.Just don't get too extreme with the rig.
The boat is quite flat on the bottom do you Think this Will be too Big a problem? I intend to use the boat in mild water and Wind conditions
Looking at those pictures,you are facing a lot of work and will arrive at a boat with sailing characteristics that won't be particularly good.Lots of wetted surface and no sign of the structure that would be needed to support a mast and sail.Unless there is a really good reason to do a lot of work on this specific hull I would recommend looking for an alternative starting point to achieve the best result for all the hours of work that would be needed.
Thanks a lot, I will probably sell this one anyway and find a more suitable one, is a normal with a more round or v shaped bottom better?
You are indeed better off to keep looking.
Take some time and learn the differences between displacement and planing hulls.
For example, a displacement hull has a lot of drag at sailing and rowing speeds. A lot of small planing hulls, like the one you showed, are sold or rented as row boats.
If you're near the coast, go into a sailing club with dinghies, ask questions, look at photos, the people there will tell you heaps of info, and they may even have, or know of small second hand boats for sale needing little work, almost ready to go, and they will take you for a sail, teach you how, and talk your ears off if you want to listen. If you join a sailing club, often they have club boats you can use for free on race days, or be a crew for another sailor and you will learn many practical skills. It's fun and very sociable usually. Yacht clubs are always looking for new members, even just to help around the club, in the rescue boats, even behind the bar, where the biggest stories are re-told bigger each time. Just ask.
