Converting 20 inch transom to 25
Discussion in 'Boat Design' started by Cumulonimbus, May 26, 2024.
  1. Cumulonimbus
    Cumulonimbus Junior Member
    Hi all,
    I am ready to bond my ply to existing transom skin but want to make sure my measurements are correct beforehand.
    I have a 5.3m Yalta Craft Odessa in Australia which i believe originally was a 20 inch transom.
    So when measuring for the my new transom marine ply i simply added 5 inches to the existing skin. Is this the correct way to go? If i measure from bottom of hull to the new cutout the measurement is 660mm / 26 inches. But this measurement is at an angle.
  2. Cumulonimbus
    Update - i put a spirit level at the bottom of the hull, measures 24.8 inches straight up to new top of ply.
    I will also be installing a hydraulic jacking plate so not sure if it would even matter too much with this on there?
  3. C. Dog
    Likes: 105, Points: 43
    C. Dog Senior Member
    Transom height is measured at the angle. Just measure the outboard from transom bracket to make sure the anti-ventilation plate is at keel level with your new transom. I have never fitted a jack plate but imagine they would allow some adjustment with positioning.
  4. fallguy
    Yup. Plus 5”.
    Jackplates are mounted in the typical ob holes. The extension of plus 5” will need to be well tabbed to the old hull.
  5. C. Dog
    It looks to be a complete transom replacement FG.
  6. Cumulonimbus
    Thanks all
