CharlieDanger99
Junior Member
- Joined
- Jun 13, 2021
- Posts
- 29
- Reaction score
- Location
- Tampa Bay
Been doing some dinghy research lately and looking at a few stitch and glue designs. Really liking the Chameleon for its nesting design. It seems there is an eternal quest for the do-it-all hull shape, but one inevitably must choose between rowing or motoring performance. If I understand correctly, the ability to get on a plane is reliant on an excess of wetted surface area at the stern to generate a lift at speed, which also creates a drag that is not conducive to rowing.
Has anyone ever tried or seen a design with detachable planing surfaces at the stern to convert a rowing dinghy to a planing hull? I came across this video (photo attached) where the guy added additional flotation at the rear of his skiff transom to keep the stern from digging when it gets up on plane, and it got me wondering if the same concept could be used on a rowing hull. I'm not looking to break any speed records, but it would be nice to have something that I could cruise around the local bay in to do some fishing that would also be a serviceable rowing dinghy for the big boat.
I realize that the hull cross section makes a difference as well, but to my eye most plywood dinghys have a relatively flat bottom, save for the upward slope to the transom. There is another old thread here discussing plates mounted below the waterline to help generate the necessary lift on disp. hulls, but I suspect something foam-cored would be needed to support the weight of a larger outboard.
