Note: This feature may not be available in some browsers.
I'm shocked, shocked to find that someone would just cut a mast down.
If you don't want it, have it lifted out and keep it and all its rigging and related parts intact.
You'd still want some kind of mast/boom, (maybe two booms, one forward of the mast,) if only for easy hoisting of tenders/heavy gear.
I think you'll find that a sailboat without a mast becomes a horrible rolling nightmare in anything much beyond calm conditions.
The motion can become violent, people aboard literally get thrown around like rag dolls, it ain't a smooth ride.
I like the idea, but she'll probably roll like a ******* with the mast cut down. Just sayin'
My opinion is that, in a hull with such rounded shapes, the wet surface of the heeled boat does not have to be very different from that of the upright boat. Therefore, the frictional resistance will not be very different.
On the other hand, the heeled boat will raise many more waves than the upright boat, with the consequent increase in the resistance due to wave formation, which is always greater than the frictional resistance.
I don't know , but this one has a 3.2 meter retractable keel, and low center of gravity. And it was recommended to keep the boom, for a small emergency sail.How many have been on a sailboat without the mast on moderate to heavy weather?
Is the reason to remove the mast to be able to go under low bridges?
You don't have to put the sails up because you have a mast.
