conversion from plywood to fiberglass?
Discussion in 'Boat Design' started by walkingwarship, May 14, 2015.
  1. walkingwarship
    walkingwarship Junior Member
    Would it be possible or wise to change from plywood to a single layer of fiberglass? The ugly stick fishing pole has a semi clear point, would it be possible to use that same thing to make a solid fiberglass hull which would glow at night just from cabin lights? I'm thinking of adding temporary supports like hard plastic sheets between the frame members and laying up fiberglass over it. Would it have be too thick to be luminescent?
  2. walkingwarship
    Would gel coat be a good idea still?
  3. FAST FRED
    FAST FRED Senior Member
    Any really well done GRP will be translucent .
    The GRP problem is always stiffness.
    Ply wood is fairly stiff , GRP would have to be thicker to match its stiffness.
    Expensive and time consuming and more work as ribs of some sort might be needed.
  4. walkingwarship
    That's what I was thinking. Bit it might be worth it. Less boat collisions etc.
    Ribs is a good word...i was thinking stringers... Anyways, sections of glass might work between the layers like bullet proof glass. I would say acrylic, bit GRP,might not adhere, and is expensive.
    This is what I'm actually looking at. A few more ribs here and there..
    Sorry so big... Didn't realize
  5. PAR
    There are no ribs in that design, at least in the traditional sense. Those are ring frames, though portions of them could be considered "futtocks" which can be also what "rib" pieces are called.
    The plywood/'glass conversion is a relatively easy thing for a designer and a common request. I perform a number per year. If you want to tackle this set of tasks yourself (I hope you like tedious work, with a calculator), buy Dave Geer's book "Elements of Boat Strength" and work through the conversion process. Most things can be converted; say a stripped hull to 'glass, maybe a plywood hull to aluminum. Often the particular design is best just reworked to suit the new method and/or material choices, so it's not overly heavy or the reverse, but basic conversions are simple enough.
  6. walkingwarship
    Tho looks like a hull that will plane right?
    I can post more pictures, but it came from: http://www.boatdesign.net/nyd/P590/
    I want to scale her up, what would be the biggest I should go? Don't care if I must buy a permit to move her. 8 ft wide is trailerable. Might make a trailer that w
    Will tilt her on her side or something though.
    I just got back into the world of sailing ⛵ and I've forgotten much.
  7. Mr Efficiency
    I'd like to hear why you want a "translucent" boat ? I'm not "clear" about the possible reasons ! :D
  8. walkingwarship
    Reason number one is to minimize risk of collisions at night. Reason two, so she won't be dark inside during cloudy days. I have a problem with sleeping too much and a dark daytime interior doesn't help. Reason number three, it would be cool.
  9. Mr Efficiency
    It actually might not be so "cool" but pretty warm in there on a hot summer day. Hothouse ? Now there's an interesting thought, would it act like a greenhouse ? I think navigation lights, windows, hatches and vents, and an alarm clock should solve most of the "issues". :p
  10. walkingwarship
    Yeah, started thinking about that after I posted the first post. However, a full fiberglass hull might be a good thing right? Could she be scaled up enough to be an ocean worthy vessel?
  11. Mr Efficiency
    I think you need to specify exactly what the boat's duty is envisaged to be, beside a floating Chinese lantern. :D
  12. ImaginaryNumber
    Maybe "transparent" would work for you. :D
  13. Mr Efficiency
    I'm tipping the author of this thread wont see this idea through to a finished boat !
  14. walkingwarship
    I'm heeling towards that too. I'm homeless and make only about a thousand a month. But if I were able... Transparent would be awesome!!!
    Especially because you could see into the water like a glass bottom boat!
  15. Mr Efficiency
    See one big White Pointer through the bottom of it, and you'll never leave the dock again !
