Steve W
Senior Member
- Joined
- Jul 30, 2004
- Messages
- 1,888
- Reaction score
- 94
- Location
- Duluth, Minnesota
It's been a long time since i've been active on here but i have a situation that i have not encountered before so i thought i would seek out some thoughts. We have a 42ft swift trawler in the shop that ran up on a reef at speed. As a result we are going to be replacing a 17ft long section of the keel with a new part which we will layup in a splash mold, well, not quite. A simple splash mold was my suggestion but management wanted to digitize it and have a mold made using mdf which we will be assembling this week. I think its fraught with potential issues, but we'll see. The existing keel is solid glass with a thickness of 8mm on the sides. To achieve this i am planning to use 9 plies of 36oz quadraxial from Vectorply. I would like to infuse it but i am concerned about exotherm, particularly as it will be twice that thickness where it laps across the bottom. I have quite a bit of experience with infusion making parts up to about 12ft x 6ft but mostly cored parts so much lighter skins. I have not been in a shop that does large solid glass infusions so i don't know how they deal with exotherm. The distance from the keel C/L up to the cut line is 25" on each side so i have done a test infusion with ten plies 6" wide x 27" to see how it flowed and what thickness i would end up with and monitored the temperature with an Infared thermometer and was surprised to see that it didn't get as hot as i expected. It did go the whole distance with just a single feed line at the end. I do still plan on an intermediate feed line just to be safe. I am using VE infusion resin btw. If i were using a simple polyester/csm splash mold i would be able to blow fans over the vacuum bag and the outside of the mold to help cool it if need be but with this mdf thing it is quite thick and will act as an insulator and work against us. It also remains to be seen if we are even able to even make it vacuum tight, if not we will have to hand lay it, if we do that we can do it over a few days and exotherm would not be a problem.
So, thoughts?
So, thoughts?
