Console thickness
Discussion in 'Fiberglass and Composite Boat Building' started by Jason Penton, Nov 27, 2020.
  1. Jason Penton
    Jason Penton New Member
    I’m trying to make a new center console for my boat and I’m wondering how thick I should I make the console it’s for a small poling skiff. Thanks
  2. Mr Efficiency
    "Thick" enough so it doesn't break in normal use, are you talking fibreglass ? Just ensure where your steering bolts on to it you have a wide backing plate to spread the load, you don't want a spongy feel to the wheel.
  3. Jason Penton
    Yes I’m talking fiber glass. You would say 1/4 inch
  4. Mr Efficiency
    You don't have to go overboard with the glass, 1/4 inch is a lot, you just need to have, as mentioned, good backing, which could be ply or a good core, of sufficient size to spread load, as part of the structure, where weight bearing attachments are fitted like steering and gear/throttle control. Otherwise you will have wobbly controls at hand.
  5. Jason Penton
  6. BlueBell
    Likes: 1,233, Points: 113
    Good solid advice there Jason.
    Mr E is proven, over and over again here.
    Rock solid 1/4" polyester.
    Bomb proof.
  7. kapnD
    Likes: 541, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    A small poling skiff should be kept as light as possible, 1/4” of fiberglass will be overkill.
    I’d make a quick Female mold of melamine, and lay up inside it, only using backing for the area where the helm is.
    philSweet and BlueBell like this.
    1. itchyglass
    2. Teaser26
    3. fallguy
    4. fallguy
    5. mookiesboatwork
    6. hyboats
    7. hardguy007
    8. Paler
    9. Gasdok
    10. Manuel R Alonso
