Connecting electric motor to saildrive
Discussion in 'Electric Propulsion' started by andysailor, Jun 18, 2017.
  1. andysailor
    Likes: 2, Points: 8
    andysailor Junior Member
    I´m planning to replace the diesel engine with an electric motor at around 12-20kw. It will be powered by a 20kwh LifePo4 bank.
    At the moment I´m thinking of connecting the electric motor to the current saildrive. It should work.
    Would it be best to direct mount it, or would it be better off to drive it with a belt or chain?
    If direct mounted, any particular coupler you would suggest?
  2. Caroute Motor
    Likes: 1, Points: 8
    Caroute Motor Junior Member
    We only have 3KW outboard. For bigger, you can consider elco or torqeedo.
  3. andysailor
    Likes: 2, Points: 8
    I'm planning a project to connect a BLDC/PMAC motor to the current saildrive. I´m more asking about the coupler between motor and saildrive.
  4. CDK
    CDK retired engineer
    To mount your electric motor directly you must imitate the present construction. A large flange similar to the flywheel so you can mount a coupler there. Of course it can be much lighter, made from alloy.
    I would not use a chain or belt drive because that would put a radial load on the saildrive shaft.
  5. Jim Caldwell
    Likes: 8, Points: 18, Legacy Rep: 48
    Jim Caldwell Senior Member
    Maybe put a bearing in the new flange?
    Barry likes this.
