Confused over fiberglass cloth
bobbrown
Junior Member
Joined
Jul 7, 2021
Posts
31
Reaction score
2
Location
SE Georgia
1/4” ply on frame…recommended 2 layers 6 oz cloth. Pretty straightforward.
6 oz plain weave = .0093
8.5 oz 2x2 twill = .0096
8.5 oz 8 harness satin = .0090
The questions are.. is the heavier fabric stronger than the lighted fabric and where does the 2,5 oz come from. If the thinner fabric uses less epoxy wouldn’t you gain strength by using a thicker fabric for not much more weight gain.
Thanks
Heavier fabric is stronger than lighter fabric of the same material and weave. There is no measurable difference between plain and twill weaves given the same material and weight. Lighter fabrics are used as surface finishes while heavier fabrics are used for structural applications. Fibreglast.com has good information about resin and fabric basics.
Thanks
epoxy use for hand lamination is about equal to the glass weight, so generally, no to your last question and yes to the first, but with penalties of 5 oz per yard with resin
the strands of the 8.5 oz are probably heavier is all
twills are more noticeable from a distance if you are varnishing the final finishes
stick to the plan..
I suppose it depends on intended use as well. If clear coating, then multiple layers of lighter glass is easier to clear out. If painting then one can use heavier cloth, use fairing compounds to smooth out and paint. Heavy strands and the way they are oriented will be harder to wet out clear. I always figure that two layers of 6 oz. with fibers running in different directions is stronger than one layer of 12 oz. Whatcha buildin?
