CharlieDanger99
Junior Member
- Joined
- Jun 13, 2021
- Messages
- 29
- Reaction score
- Location
- Tampa Bay
I made a post a few months ago about the design considerations of converting the deck-stepped rig to keel-stepped on my Swiftsure 33 restoration project. After some careful thought and several conversations I've decided I would prefer to keep her in the deck-stepped configuration. The reason for thinking about this, however, is that due to improper sealing of hardware at some point, the compression post has rotted out and needs replacing. In the original construction, the 2 main bulkheads are fiberglass laminate cored with 3/4 in balsa. The aft bulkhead makes a 90 degree radiused turn to forward along the centerline, and another piece of 1 in plywood is glassed next to it directly below the mast on the port side. This seemed relatively scant to me upon first inspection, but I believe the load was well distributed between the bulkhead and doorframe for the head just forward of the mast step, as there is no sign of deformation after 60+ years. The only rotten section is directly below the mast, so I expect to cut out the ~10 in wide vertical section and sister in a new support. I could go to the local lumberyard and get a quote for a hardwood post, but I have plenty of marine ply offcuts already laying around that I could epoxy together to make a new vertical beam. Assuming this would be well tabbed back to the existing structure, what thickness should I be aiming for to have adequate buckling strength? There isn't much room for anything other than a butt or short rabbet joint so I expect it will need to be a bit thicker than the original to account for the stress at the joints.
