If you do decide to strip plank,I'd be surprised if you could get a highly finished boat completed before the autumn.Which isn't to say that building one can't be done,rather it can't be done rapidly and the two factors that make it so are building a jig to plank over and then filling and fairing over the cloth.
That's what I always thought about strip planking, that it's one of the most laborious ways of building a boat. But I always thought that only applied to wood, because of having to rip and profile so many strips and joints, requirement to have very close fits for the glue to work, etc. With the foam though, what would take so much time? The mould seems to be just a bunch of temporary frames on a strongback, looks like something that could be cut out and set up in a day. Foam strips seem not to need any special forming on the edges due to expanding PU glue. And it should be easier to sand than wood anyway. Glassing is probably about the same as on a regular stitch&glue boat. Am I missing something? I've never done strip planking, so my assumptions could be entirely wrong, I'm just wondering what takes that much time with this method?
400 gsm biax on the outside and 300 on the outside should be plenty. Probably no frames will be required but perimeter of hull neets stiffening and at least some deck to provide torsional rigidity. If you fall on your knees repeatedly in the exact same location while the hull is sitting on some rocks it is possible to cause some damage. I did the equivalent driving my canoe repeatedly into rock shoals ~ 120 times over a 4 day period on a remote river trip fully loaded with gear. The foam was compressed on the outside in line with the front of the minicell seat I sat on.
I missed the earlier comment on your raised floor. Consider making molds for the hull from floor up and use XPS foam for the bottom, Hotwire the foam in section to match your station spacing. Glue the the XPS blanks together and fasten to mold, fair lightly. Strip it all, glue the strips directly to XPS. Should make a slightly lighter truly unsinkable hull a bit quicker. The inside might be easier to dent though ;-)
Wait, you mean a single layer of 400gsm fiberglass on the outside, and single 300 gsm on the inside? That's all that's needed? I would have expected far more weight and layers. And that is really enough? How much did the boat from your photo weigh in the end? Also, is that foam you mentioned close-celled? If the boat receives damage and water gets to the foam, won't it cause all sorts of issues (osmosis, massive additional weight, etc.), since it's not really possible to dry out?
I didn't quite understand the procedure you described for making a raised floor. Did you mean that one side of the foam would not receive fiberglass at all? Or that the entire volume between the bottom of the boat and the floor would be completely filled with foam? And with your suggestion to fill XPS between the station moulds, would it still be possible to pull the station moulds out afterwards, or did you intend for them to remain permanently installed in the boat as bulkheads?
