1. The Marketplace Forums can be useful for members who know one another well from forum discussions and offline communications and wish to post boatbuilding tools, drafting tools, molds and tooling, and other professional equipment for sale or trade. However, caution and good judgement should always be used. Especially when considering any business with anyone not already well known to you and trusted, due diligence must be used to confirm details and identity and be sure the transaction is safe before any money or property changes hands. Always use good judgement and perform due dilligence and follow these guidelines.
Cold rolled steel coils for sale
Discussion in 'Marketplace' started by john33214, May 30, 2024.
  1. john33214
    Likes: 0, Points: 0
    john33214 New Member
    Wholesale price cold rolled steel coil prime quality customized cold rolled steel sheet/strips are important materials widely used in modern industry. Cold rolled steel coil, is a strip or plate treated by cold rolling operations with a smooth surface, uniform thickness, precise dimensions and excellent mechanical properties. It has a higher degree of work hardening and therefore has better strength and toughness. Compared with hot rolled steel coils, cold rolled steel coils have a smoother surface and are free of iron oxide, but their mechanical properties may be slightly inferior to those of hot rolled steel coils. However, its greater dimensional accuracy and smaller shape and size deviations give it a significant advantage in specific application scenarios. It also has many features.
    Firstly, it is accurate in size, uniform in thickness, and the thickness difference of the coils generally does not exceed 0.01-0.03 mm or less, which can meet the requirements of high-precision tolerances. Secondly, it is possible to obtain extremely thin strips that cannot be produced by hot rolling (up to 0.001 mm or less). Thirdly, the surface quality of is superior, there are no defects such as pitting, hot-pressed iron oxide, etc., which are often found in hot-rolled coils, and coils of different surface roughness (glossy or hemp) can be produced according to user requirements. Fourth, the cold rolled plate has a good mechanical properties and process properties (such as higher strength, lower yield limit, good deep drawability, etc.). Fifth, high-speed rolling and full-continuous rolling can be realized with high productivity. Additionally, it is widely used in various areas. Firstly, it is widely used in the manufacture of home appliances such as refrigerators, washing machines and microwave ovens, as well as the shells and fittings of electronic products such as computers and mobile phones, due to their high surface finish and ease of processing and maintenance. Secondly, it is used in well-known automotive industries, such as Chery, Qingdao FAW, etc., mainly for the manufacture of key components such as automotive panels and bodies. Thirdly, it is often used in the construction industry to make components such as roofs, walls and floors, where their excellent corrosion resistance and strong toughness help to extend the service life of the structure. Finally, it is also used in other industries such as office furniture and daily-use hardware.
    The cold rolled steel coils and steel sheets/strips products we offer are not only of superior quality, but also competitively priced to meet wholesale needs. What’s more, we provide excellent customization service, which allows us to customize production according to customers’ specific needs and specifications, ensuring that the products can perfectly fit customers’ actual application scenarios. We look forward to establishing a long-term relationship with you and jointly promoting the development and progress of the industrial field.
  2. john33214
    Likes: 0, Points: 0
    Perforated holes equal and unequal galvanized slotted angle steel bars are a specially designed metal material, below is a detailed description of this product. The thickness is 0.8-2.5mm, and length is 1M-6M, or as your request. The color is white, red, blue, and can be customized.
    The product is mainly made of steel through a series of processing, including hot dip galvanizing treatment, which makes the steel surface covered with a layer of zinc, thus enhancing its corrosion resistance. The galvanized treated angle bars have good corrosion resistance, strength and hardness. The zinc layer can effectively resist atmospheric erosion and chemical corrosion, thus greatly extending its service life. In addition, it has excellent workability and malleability and is easy to cut, drill and bend into desired shapes and sizes. The product is available in two types, equal and unequal, meaning that the two sides can be the same or different lengths. In addition, the products have a slotted design, a feature that makes them more convenient and flexible in certain applications. Meanwhile, the products are available in a variety of size specifications to meet different occasions and needs. Another great advantage is the perforated design. The perforated design makes the angle bars easier to install and use, allowing for easy connection and fixing. The location and number of holes are usually determined based on the specific specifications of the product and the needs of the application. This design also increases the customisability of the product, allowing the user to choose a product with specific hole positions and diameters according to actual needs.
    The product is widely used in various fields. Construction field: perforated equal and unequal galvanized slotted angle bars are widely used in the construction field, such as for erecting frames and supporting structures of buildings, such as roofs, wall skeletons, door and window frames, etc. Industrial field: in the industrial field, it is often used to make shelves, storage racks, support frames for machines and equipment, etc. Its high strength and good corrosion resistance make it ideal for these applications. Other fields: in the fields of transport, electric equipment, agriculture, etc., this product is also widely used due to its excellent performance. To sum up, perforated equal and unequal galvanized slotted angle bars are a metal material with many excellent properties and a wide range of applications. The quality of our products is unquestionable. We have obtained related international certifications. More importantly, it should be noted here that the minimum order quantity is 20 tons. If you have any further questions, please don’t hesitate to contact us.
