Cold-moulded dinghy plans?
Discussion in 'Sailboats' started by tomkcook, Oct 1, 2018.
  1. fallguy
    Likes: 1,684, Points: 123, Legacy Rep: 10
    fallguy Senior Member
    The building of hull shells is a very small, but vital part of a boat build.
    For a 40-50' boat, buying the hull is also an option. Cold molding a large hull is a sure recipe for a boat you never finish.
    The thing to do is write a statement of requirements, find the right design, and the build method will be apparent. Foam sandwich, developable panel or monocoque construction in foam or strip planking.
    Cold molding is a recipe for failure.
    I am building a developable panel cat 32' long foam sandwich vac table. It is a full time job for me and was a 24 month plan, but my hip failed, so the time will go an extra year. I would recommend you build your dinghy using infusion of either panels or the full hull.
    But first, find the design you like. Then the build method will be vivid.
