Cobalt Catamaran Foiler
Discussion in 'Multihulls' started by Doug Lord, Mar 2, 2014.
  1. Doug Lord
    Doug Lord Flight Ready
  2. wet feet
    Likes: 106, Points: 43, Legacy Rep: 124
    wet feet Senior Member
    I had the chance to take a look at the vessel in question at the weekend.Nice hulls,but a lot of refining will be needed to make all the systems work.I wasn't too impressed by the mast steps or the upper foil attachments.
  3. Munter
    Likes: 11, Points: 18, Legacy Rep: 125
    Munter Amateur
    I thought the same thing watching the video. The foil hinges seem underweight compared to what you see on other foilers. I also wonder about the big holes drilled in the base of the mast. Even if they contain the downhaul loads to the mast tube itself I worry about the longevity of those bolts through the base.
    Full credit to them for bringing a project to a stage where it reaches the water but I wonder whether the game hasn't moved on a bit from where it was when key design decisions were being made on this project. The last AC cycle resulted in a lot of learning that may not have made it into this boat due to the stated 3-year build time. They have also taken the approach of attempting to integrate several major design innovations in one go - which history shows can be a painful process.
    Regardless - they have a boat on the water and will no doubt learn a lot about what makes it tick in the coming months. That in itself is a pretty good achievement.
    If I ever need an exit strategy for my technology I know where to go!
  4. Doug Lord
  5. Baltic Bandit
    Baltic Bandit Previous Member
    Well the rig looks a bit too soft and the sails look a bit too full. A purpose built boat to break a particular speed record is as much the future of the sport as MariCha IV is/was
  6. pogo
    pogo ingenious dilletante
    Except ? ;)
    pogo
