coax switch for AIS
Discussion in 'OnBoard Electronics & Controls' started by 23feet, Mar 4, 2019.
  1. 23feet
    Likes: 12, Points: 8, Legacy Rep: 10
    23feet Junior Member
    I would like to use an inexpensive AIS receiver on my boat, and don't want to pay for an expensive splitter.
    I am happy not being able to use both the ais and vhf at the same time with my one masthead aerial.
    Could I not just use an inexpensive coax switch when I want to use either the ais OR the vhf?
    Thanks,
    Roger
    Likes: 2,095, Points: 123, Legacy Rep: 2031
    A cheap switch will likely be noise, degrade the signal and probably won't last long. Your life and safety may depend on the VHF or AIS functioning. There are other, non-critical, areas to save money on. A splitter costs about $65.00. How much are you saving with a cheap switch?
  3. 23feet
    I have not a seen a splitter as inexpensive as that - usually $200+. Can you point me in the right direction?
    Thanks,
    Roger
  4. gonzo
  5. 23feet
    Thank you. I had seen those but thought that I would need a "marine" product. This is indeed a better solution.
  6. gonzo
    They don't need to be completely waterproof if you install them below decks
  1. fritzdfk
  2. the brain
  3. sdowney717
  4. sdowney717
  5. Charlyipad
  6. Jorda
  7. Daniel Dragic
  8. the brain
  9. Marcial Campos
  10. mikealston2428
