closed cooling outboard?
Discussion in 'DIY Marinizing' started by fishon91, Feb 22, 2011.
  1. CDK
    CDK retired engineer
    I don't think so. The largest items to pass the slits are small leafs: the pump can handle that.
  2. Frosty
    Frosty Previous Member
    Small leaves and big leaves and some more stuff you dont know about.
    A filter would be good and advisable. Like a proper boat.
  3. fishon91
    fishon91 Junior Member
    gonzo, i meant JUST relocating the water inlet and bypassing the pump with electrical pump. no radiator.
    i dont even know that the advantages would even be worth the work on this anymore.
    the boat is a 1436 and a thin hull, no air propeller is goin on this rig.
  4. fishon91
    sorry, didnt see these last two posts.
    youre saying i wouldnt need to worry about sand or little bits of mud goin through the motor?
    of course as long as i keep a good eye on everything, flush the motor after every run.. etc...
  5. Frosty
    Fishon with all due respect no one has done this, everyone is guessing.
    If you want to do stuff like this you need to be mechanically minded and able to work things out on your own.
    Sooory but that how it is,-- no one has done it.
  6. Submarine Tom
    Submarine Tom Previous Member
    Also, you mentioned, cost is a big factor. When you start pioneering things not commonly done, you run into added expenses, down time. Two steps forward, one step back kinda stuff. Keep it simple, and do what's proven. You're in a tough spot my friend. Good luck.
    -Tom
  7. fishon91
    HAHA im in a very tough spot. i prbably will and up not doin anythin like this. i built a longtail a couple years ago and ran into the added expenses, one step forward, two step back kinda thing. and thats why im in the position im in now. i jus need to keep my eyes out for a good longtail for a good price that i can afford.
    thanks yall
  8. Erich_870
    Likes: 2, Points: 0, Legacy Rep: 29
    Erich_870 Junior Member
    You really should contact that guy I mentioned. He's done it and can tell you all about it.
    Erich
  9. fishon91
    erich, i just tried to join the refuge forum and it wouldnt let me use a yahoo or hotmail email, those are the only two emails i have access to. is there another way?
  10. Erich_870
    Arrrg, that's the most annoying thing about that forum. I had to use my work email for that exact reason.
    I'll see if I can find the exact reference and send you the link.
    Erich
  11. Erich_870
  12. pistnbroke
    Likes: 34, Points: 48, Legacy Rep: 404
    pistnbroke I try
    briggs and stratton will push you about 10 mph...b and s dont make them any more so you need look at second hand ...
  1. Lawrencemd
  2. dj0443
