Cleaning off the butyl tape
Discussion in 'Fiberglass and Composite Boat Building' started by Tungsten, Jan 26, 2013.
  1. Tungsten
    Tungsten Senior Member
    I vac bagged down a part onto a peelply surface.The tape has left a nice black line .Any idea on how to clean this off?
  2. PAR
    Toluene, dish detergent, xylene, mineral spirits and turpentine are the most common chemicals.
    WD-40 does a fair job, though a combination seems to work best. Scrub the area with a degreaser, like dish detergent. Hit the stubborn areas with WD-40 and scrub again. If still having trouble, step up to mineral spirits and the harsher chemicals. The original version of "GoofOff" does a good job, which is a mixture of toluene/xylene and a few other things. Test the surface to see it it will tolerate these chemicals. The harshness list descends from: xylene, toluene, turpentine, mineral spirits, then WD-40 and detergent.
  3. Tungsten
    OK thx tried a small area with varsol worked well.I;ll let that dry then scrub with dish soap.My fear was that i would mess up the epoxy surface but i guess not.
  4. PAR
    Most epoxies are very tolerate of chemicals, particularly if used and wiped clean.
  1. John Rivers
  2. itchyglass
  3. bucketlist
  4. DogCavalry
  6. IronPrice
  7. youngfella87
  8. Fabuglas74T
  9. Nicko1985
  10. gtflash
