cleaning closed cell pore foam before glassing?
Discussion in 'Fiberglass and Composite Boat Building' started by roob76, Jan 21, 2007.
  1. roob76
    roob76 Junior Member
    what solvent is safe to use for cleaning high density pore foam before glassing over it to seal it? i think acetone will dissolve it so i want to stay away from anythiong like that.:confused:
  2. bobothehobo
    Likes: 4, Points: 0, Legacy Rep: 47
    bobothehobo Junior Member
    How dirty are we talking about??
    If it is just dusty I would blast it with compressed air.
  3. roob76
    yeah it is just basically the dust from chopping off some and sanding it level
  4. bobothehobo
    I would just vacuum and/or blow off with compressed air then.
  5. roob76
    done. thanks for the help. i blew it off then wet it out with epoxy and let it set for a couple of hours then laid glass. :D
