CLC PocketShip, Schreyer CROW, or ... ? Looking at home builts < 16'
Discussion in 'Sailboats' started by Mark Sumner, May 26, 2020.
If you were building a tiny cruiser for the heckuvit, which would you pick?
  1. PocketShip
    0 vote(s)
    0.0%
  2. CROW
    1 vote(s)
    25.0%
  3. Something else
    3 vote(s)
    75.0%
  1. Mark Sumner
    Mark Sumner New Member
    I've built a small skiff, and I regularly sail a very small sailboat (my 1984 Howmar Phantom, basically an old Sunfish clone). Now I'm looking to build something for fun that looks a little more ... shipish.
    As it happens, I live on a small lake, so I have a handy spot to dunk anything I build and test it out. However, there's a 16' limit for boats on the lake. So, even though I definitely plan to drop whatever I build on a trailer and take it places more interesting than my backyard, I'm taking that 16' as a limit on this project.
    I've looked at CLC's PocketShip, which is lovely. And at Roy Schreyer's CROW, which is decidedly un-lovely, but packs a lot of boat into 15'8" (it also helps that I've watched a build video on the CROW and seen it constructed without the use of tools I don't own or skills that seem vastly out of my range).
    Still, I'd like to hear what else might fit in the category of these little boats. Must be under 16', have something of a cabin, and be capable of operating with a shallow draft in a pinch, While much of the lake is > 25' deep, the area right around my dock is only around 3-4' and can get lower in the midst of a dry summer. And the boat should also sail well and be up for something more adventurous than just my lake. Like, say, a trip to the Texas 200.
    Oh, and it must be build-able for someone whose skill set includes enough woodworking to build a deck or a shed, but not the skill to hand carve a violin.
    Suggestions? Kit build or plan build are both okay.
  2. Dolfiman
    Likes: 698, Points: 113
    Dolfiman Senior Member
  3. Mark Sumner
    Thanks, Dolfiman. It's certainly a very attractive little boat. And it's impressive that so many have been built (of the older form). What they show of the design seems straightforward, and the use of a weighted keel and centerboard rather than a leeboard certainly helps make the boat appear more capable--even if it also seems a bit of threat to my skills. My French isn't up to some of the details. I believe I'll give them a nudge and see if the study plans are available in English as well as seek out any videos of a new model under construction.
    If nothing else, I'm acquiring a library of study plans, which in itself is no bad thing.
  4. Dolfiman
    It is said that "a translation into English is possible. Ask the designer" :
    Contact | François Vivier, naval architect http://www.vivierboats.com/en/contact-en/
    In complement in case of, photos and comments (in French) of the successive steps of an home building of a Maraudeur, photos at least can give you an idea of the various tasks and skills involved. To note that the home builder here took the option to draw and cut himself the plywood panels with a jigsaw :
    Project genesis :
    Construction amateur d’un Maraudeur de J.J. Herbulot et François Vivier https://www.bateaux.com/article/30123/construction-amateur-d-un-maraudeur-de-j-j-herbulot-francois-vivier
    Setting up the building site :
    Construction amateur d’un Maraudeur, mise en place du chantier https://www.bateaux.com/article/30125/construction-amateur-d-un-maraudeur-mise-place-chantier
    The planking, in one ply 6mm (for the flat or developable panels) or 2 x ply 3mm (for the rounded bilge) :
    Construction amateur d’un Maraudeur, le bordage de la coque https://www.bateaux.com/article/30217/construction-amateur-d-un-maraudeur-bordage-de-coque
    The roof , deck, floors, daggerboard, rudder, … :
    Construction amateur d’un Maraudeur, enfin un rouf ! https://www.bateaux.com/article/30293/construction-amateur-d-un-maraudeur-enfin-un-rouf
    The painting, the lead ballast :
    Construction amateur d’un Maraudeur, de la couleur pour la coque https://www.bateaux.com/article/30367/construction-amateur-d-un-maraudeur-de-couleur-coque
    The rig, the first launch :
    Construction amateur d’un Maraudeur, enfin les premiers bords https://www.bateaux.com/article/30440/construction-amateur-d-un-maraudeur-enfin-premiers-bords
    The stability test, the flooding test, the final building time (650 h within 1,5 year) and final cost (7520 Euros) :
    Bilan chiffré de la construction amateur d’un Maraudeur https://www.bateaux.com/article/30558/bilan-chiffre-de-construction-amateur-d-un-maraudeur
    A 1964 Maraudeur, still in great shape, as the sailor and his dog :
  5. Will Gilmore
    Likes: 531, Points: 113
    Will Gilmore Senior Member
  6. Mark Sumner
    Thanks, Will. Looks very neat as an open boat. I need to get a better look at one built with a cuddy to see what kind of space it provides, but I definitely like the look.
  7. Peter the boatbuilder
    Peter the boatbuilder New Member
    Hi Mark. I have to go with Crow for a couple reasons. Ease of construction is one part of it while the available interior space is valuable. Marauder will be able to sail marginally faster but not as comfortable for camp sailing.
  8. CT249
    Likes: 266, Points: 83, Legacy Rep: 215
    CT249 Senior Member
    Surely the Maradeur will be much more than "marginally" faster. Look at the 8ft PD Racer, which is similar in basic design to the Crow and would probably be proportionately faster than the Crow. The PD Racer is rated much slower even than an Optimist or a US Sabot, which means it's just one of the slowest dinghies afloat even accounting for its short length.
    There seems to be no reason why the Crow would be faster than a San Francisco Pelican or West Wight Potter 15, which are about as slow as a PD Racer and therefore much slower than even an Optimist or Sabot. The Marauder in contrast is quite a good performer; it's rated about as fast as a Laser Radial. A boat of that sort of performance is in a very different class to the probable performance of a Crow.
    It's hard to see why the Pocketship would be any faster than say the West Wight, and therefore it may not seem to be a good performer for someone coming from a Sunfish type.
    Other boats to try would be the ageing but well tried Hartley TS16 or the Cherry 16, or some of the French boats I'll remember later.
  9. Peter the boatbuilder
    Marauder is faster. Cruising for a week the Crow wins.
  10. Dolfiman
    Another one, amore recent design, the "Souriceau", with same length than the Maraudeur but with more cabin volume, a minimum draft of 0,57m, but also more heavy (530 kg / 325 for the Maraudeur), i.e. more coastal micro cruiser than camping boat :
    Souriceau Full Plans https://duckworks.com/souriceau-plans/
  11. skaraborgcraft
    Likes: 264, Points: 63
    skaraborgcraft Senior Member
    Maderski Setka. The centreboard version will better suit your needs.
    but is till self righting. The fixed keel version has numerous Atlantic crossings to its credit. Probably the best "unknown" home build off-shore capable yacht for those on a budget that want to build their own boat.
    Will Gilmore likes this.
  12. Milehog
    Likes: 182, Points: 43, Legacy Rep: 215
    Milehog Clever Quip
    My 2¢.
    Sail well and Texas 200 leave the CROW out. Think motorsailer especially upwind.
    The Maraudeur is sweet, I'm in love! The build will take skill and time and standing rigging is time consuming at launch and take out.
    Catbird 16. Easy build yet has side decks and coamings to keep you dryer. I'd suggest the yawl rig for two reasons, the lug sail is easier to reef (I love mine) and it gives room to stand and stretch your legs. Sharpies have a few vices, peccadillos if you will, associated to the flat bottom. Some people are okay with them, others aren't.
    Lapwing 16. B&B boats do well in Texas 200 and raid events. their designer (RIP) knew his craft. Some sort of canvas cuddy would make this a real contender. My choice.
    The Pocket Ship is fascinating, quite a boat and quite an investment for so small a boat.
  13. Buckethead
    Buckethead Junior Member
  14. Milehog
    Milehog Clever Quip
    That is a very cool little hot rod.
