Chevy 350 oil pump
Discussion in 'Gas Engines' started by mikealston2428, Apr 22, 2013.
  1. mikealston2428
    mikealston2428 Senior Member
    Hi everyone,
    Is there a gasket between the oil pump and the block ?
    Many thanks in advance for answers.
    Likes: 2,417, Points: 123, Legacy Rep: 2031
    No, it is just metal to metal.
  3. mikealston2428
    Thanks for answer Gonzo.
    The oil pan baffle has a mixer of my lock nuts and normal nuts who ever did the last rebuild was a bit silly, my question is should they all be nylock nuts and not worry about any torque setting.
    The oil pump bolt torque is 65 ft pnd is this correct.
    Many thanks
  4. gonzo
    They are not nylocks but pinch nuts. That is, the threads at the end are squashed a bit so they drag and not come loose.
