sharpii2
Senior Member
- Joined
- May 31, 2004
- Messages
- 2,282
- Reaction score
- 346
- Location
- Michigan, USA
I think your time estimate is so far off that it's not even wrong. I'm thinking more like 10,000 hours. And even that might be a bit skimpy. The size you are talking about would likely displace at least 19,000 lbs. That's a whole lot of boat. Also, time must be traded against cost, if you are doing the build yourself. The reason for this is that you will have to do a lot of scrounging and bargain hunting as you go along. Except for the hull building materials, nothing is going to be new. And a lot of stuff is going to have to be jiggered to make it work. To get an idea of what you may be getting into, you aught to check out "Salt & Tar" on YouTube. They built a 35 footer over a seven year period. The boat they built was extremely simple. It was made of wood planks and has a single-chine bottom. It has a re-purposed diesel which is conected to the proppeler with an automotive style drive shaft. The man who built it had done numerous boat restoration projects, including both wood and fiberglass, so he was no novice.
To keep your building time even within 10,000 hours, you are going to have to go with an extremely simple hull design. Probably a flat bottom with flared sides and a bolt-on keel. Your choice of hull building materials will likely be limited to plywood, steel, or aluminum, with aluminum, because of its cost and difficulty in welding, being a distant 3rd choice. Any other material choice will likely add tremendously to your building time.
Your rig choice, too, may well be tied to your building time and cost limitations. If you go with a Marconi (Bermudan with Spreaders) rig, for example, you may be able to get used spars and sails that are good enough.
You can go for a cutter*, ketch** or even schooner set up with this type of rig.*** A sloop would require roller-furling, which would likely cost you more than the rigging needed for a second jib. The ketch and the schooner rig would require two masts and more standing rigging, but would be easier to make self-steering without a vane or autopilot.
The finish of your boat is likely to be more work-boat like than yacht like. Getting a yacht quality finish takes loads of time.
The best keel for your project will likely be a long, shallow type, to better distribute its loads along the length of the hull, and allow the use of concrete and steel, rather than the more expensive lead for ballast. It won't have to be the length of the waterline, and you can have a separate skeg and rudder.
Cave-lockers, with good doors or hatches, are a good alternative to drawers and are a handy way of dividing your stowage up (and keeping everything in plae during rough conditions), without having to go through a lot of time consuming cabinate-making. See the YouTube channel "Wind Hippie Sailing" to see a a good example of such.
*A cutter is a single mast rig, with the mast stepped further aft than that of a sloop, and has a second stay, which runs parallel to the forestay, on which the second jib (aka staysail) hanked to. It usually requires a pair of back-shrouds, which connect to the mast at the same height as the inner-fore-stay.
**A ketch rig has two, masts with the the taller one being in front of the shorter one.
***A schooner rig has two masts with the masts either being of equal height, or the taller one being in the back.
