Cheap outboard motor that can be controlled by steering cable
Discussion in 'Boatbuilding' started by Jatgm1, Jul 26, 2025.
  1. Jatgm1
    Likes: 1, Points: 3
    Jatgm1 Junior Member
    So I've noticed that the more expensive motors have a tube which gives them theability to use that to steer the outboard motor with a steering assembly and cable. I can't figure out how to do that with a smaller motor that's super cheap. Is there a way I can rig that up or buy a really cheap motor that has this assembly?
    Likes: 2,415, Points: 123, Legacy Rep: 2031
    Motors with remote steering are usually on the bigger sizes. You can connect a cable steering system to the tiller of the smaller and cheaper motor. You will also have to rig a throttle control and shifter (if it has one).
