Chainplates
Discussion in 'Boat Design' started by disneytime, May 8, 2012.
  1. MikeJohns
    Likes: 210, Points: 63, Legacy Rep: 2054
    MikeJohns Senior Member
    For your calculations; B is the Bearing surface, T the tensile areas, S the shear areas.
    The pin will be in double shear and usually you'd make the chainplate shear strength greater than the pin's.
  2. sabahcat
    Likes: 28, Points: 0, Legacy Rep: 273
    sabahcat Senior Member
    Look again, it has a spreader bar.
    remember that these are chainplates the stays will be angled towards top of mast and the fibres will be oriented in the same angles.
    A wide spreader bar and vertical lift would make the load path different to what the fiber angle is.
    Why would you assume that?
