SVQuestofPaget
Junior Member
- Joined
- Apr 2, 2021
- Posts
- Reaction score
- Location
- Boston, MA
Hey Folks - Longtime reader and first time poster here - I'm not sure if this question should be posted here or in Boat design, but here goes! I've been restoring a 39ft Frers custom sloop, his first commission after leaving S&S in 1969. Hull design is very similar to an S&S Swan 40, though lighter displacement at 16,300lbs, and with 670sqft of sail area. The boat and sistership were built by Frans Maas in just three months to be ready for the Admiral's cup series, and many of the period-acceptable construction methods that were employed at the time have now become issues.
I'm currently considering the chainplates, which consist of a 5mm stainless gusset and 8mm welded lug, glassed into the hull via three long welded tabs. The area of the hull has had no visible moisture damage, though water has leaked down the lug (which penetrates through the deck) for decades. The deck rotted in this area from water intrusion, though the hull shelf appears quite solid. My concern is the inability to inspect where the chainplate pierces the deck and shelf, and that they're over 50 years old and have never been serviced or replaced. A few incisions in the shelf adjacent to the lugs have revealed minor staining of the metal, with some stubborn areas that don't appear to clean up with scrubbing - crevice corrosion? Fatigue? Can't say without removing, and I don't want to trust them as they are.
In anticipation of long distance sailing and bringing peace of mind, I'd like to address the old chainplate lugs in one of two ways. The first option would be to cut the existing lug at the hull flange, and drill the 5mm plate to receive new chainplate lugs. I don't look forward to drilling 1/2" holes through the stainless gusset, but it would be the simplest way to install new lugs - the gusset and glassed tabbing is dry w/ no delamination or rust evident.
The more thorough option is to remove the stainless frames entirely and glass in new composite knees in their place, through which a standard stainless chainplate lug would be through bolted. In this case, I've drawn the knee to be longer and wider for greater surface area against the hull. What to use as a base material for the knee? G10, Plywood w/ epoxy anulus for each bolt, Coosa? According to the blueprints, the hull is solid glass with extra laminations in the way of the chainplates.
I'm not an engineer or designer, but prefer to work along the adage of "nothing too strong ever broke". I'm looking for input from engineers or designers on the forum as to the validity of either of these solutions, as well as preference on base/core material for the composite knee. I'm also very happy to pay an engineer or designer for their time and assistance if anyone wants to message me directly.
Thank you in advance!
-Eric
Quest of Paget, Login • Instagram https://www.instagram.com/sv_questofpaget/
-Eric
