Centerboard sleeve for small sailboat
Discussion in 'Fiberglass and Composite Boat Building' started by mccdeuce, Aug 28, 2009.
  1. mccdeuce
    mccdeuce Junior Member
    I am building a ply/glass composite 14ft skiff.
    I have run into a problem with gluing the centerboard sleeve into the boat. As the epoxy is curing it is expanding, pinching the sleeve slightly which causes the centerboard to no longer fit into the sleeve. I have tried building the sleeve with different materials so that it is stiffer but I have yet to successfully install a working centerboard sleeve.
    Any advice would greatly be appreciated.
  2. Itchy&Scratchy
    Likes: 3, Points: 0, Legacy Rep: 117
    Itchy&Scratchy Senior Member
    Why not build the centreboard to fit the boat rather than the other way around.
    j
  3. PAR
    Likes: 505, Points: 93, Legacy Rep: 3967
    What are you calling the centerboard sleeve? The case? the pivot pin? Do you have any photos? Epoxy doesn't expand as it cures, what type of epoxy are you using?
  4. mccdeuce
    expanding may not be the right way to describe what I think is going on.
    I call the centerboard sleeve a case that is formed to the centerboard and then a box built around it. (Technically I guess this would be a daggerboard)
    epoxy is us composites medium cure
  5. alan white
    alan white Senior Member
    Whether or not a sleeve as described is recommended, a dagger board needs some clearance (1/4" is good) to slip in and out easily.
    You think it's hard to slide now... wait until you get some marine growth on there.
    If you want it tight, think about a vertical ridge, something thin like HDPE strips set in dados. You want a good fit, but you don't need to contact the whole case with the board.
  6. PAR
    Yep, that's a daggerboard and the thing it slides into is a case.
    I'm not sure why you want to install a sleeve inside the case, but if you do, it should be as Alan suggested from a material that is fairly slippery, like Teflon or HDPE.
    I prefer less then a 1/4" clearance inside a case, but not much, say 1/8" to 3/16". At the low end of this scale, the board will probably jam frequently, at the high end, it will sing like a humming bird.
    What do the plans call for?
  7. mccdeuce
    There are no plans. Its a javelin class boat. (Box rule racing skiff)
    I have gel coated the inside of the sleeve so that it is slippery. I wanted to build the sleeve so that it has a relatively tight fit and cannot bounce around.
    I think the bottom line is that I need to increase the clearances. 1/4" seems high for me, but 3/16" seems more reasonable.
