Cement dust, awlgrip and a trimaran
Discussion in 'Fiberglass and Composite Boat Building' started by HydroNick, Mar 23, 2016.
  1. HydroNick
    Likes: 4, Points: 8, Legacy Rep: 38
    HydroNick Nick S
    My Farrier F-25c is on its trailer in marina in north Vancouver between a sulphur pile and a cement plant; apparently, one of the cement plant hoppers has ruptured and the marina is now covered in cement dust. I am hoping the local boat repair guy is going to have a look tomorrow.
    The boat is awlgrip painted carbon fibre over a balso core Does anybody know how alkali cement dust and
    • the canvas cover
    • Awlgrip paint
    • outboard motor
    • Galvanised trailer
    Will fair and anything to look for in particular..oh carbon fibre mast with both ss and aluminum fittings
    Thanks
  2. Mr Efficiency
    That is pretty bad luck, I'd imagine the biggest immediate problem is moisture combining to set the cement, which is going to be an awful mess to fix.
  3. PAR
    The morning dew will wet and begin the cure process. If it was me, I'd just start hosing the crap out of it immediately, to dilute and wash off what you can. Waiting until mother nature does the deed, means you'll have to removed hardened concrete.
  4. Steve W
    Likes: 94, Points: 48, Legacy Rep: 608
    Steve W Senior Member
    Take lots of photos to document for the insurance company in case you need to file a claim and then do as par said and wash it off, don't wait for it to get wet and start to set up.
  5. DGreenwood
    Likes: 40, Points: 28, Legacy Rep: 507
    DGreenwood Senior Member
    Lots of water now. Flush and flush. Can't say what will happen to the canvas.(I would shake it out before I flushed it) The best option is to not need to go after insurance money. None of that stuff should be hurt by cement dust as long as you get it off with lots of water.
  6. Maniek
    Maniek Junior Member
    Yeeeees...water,water...on last stage add a bit of vinegar and again water....
  7. SamSam
    SamSam Senior Member
    Probably too late now, but you don't want to breath cement dust as the moisture in your lungs is perfect for starting the set-up process.
    1. AKfisher
    2. Cleanriver
    3. PNW
    4. brokebosun
    5. Tom Mckinney
    6. Tiger51
    7. 95Sailfish176
    8. chowdan
    9. luders27
    10. fallguy
