caulking material ?? Arthur Edmunds
Discussion in 'Fiberglass and Composite Boat Building' started by hyboats, Jan 22, 2013.
  1. michael pierzga
    michael pierzga Senior Member
    Dont know about sheer clamps, but for joints that must be waterproof and not made permanent with adhesive , 3m strip caulk is used .
    Its nice and clean to work with. Because of its density, only use it for joints were you can develope substantial clamping pressue.
    I prefer the gray 3M strip caulk
    http://3mcollision.com/3m-strip-calk-08578-black.html
  2. PAR
    3M-8578 (Strip Caulk) is butyl rubber. It doesn't have the elongation of the polyurethanes (not even close), but I've seen butyl seals, gaskets, etc. after 30 - 40 years of use, still pliable. If you don't have much movement it's a fine way of doing it.
    1. iceboater
    2. Gasdok
    3. ondarvr
    4. Skip Johnson
    5. motorbike
    6. Mark C. Schreiter
    7. Gasdok
    8. Robinfly
    9. mizkuzi
    10. Mike Inman
