catamarans vertical clearance
Discussion in 'Boat Design' started by Brian.Lin, Nov 27, 2017.
  1. Brian.Lin
    Brian.Lin Junior Member
    dear Sir,
    how to decide the catamarans vertical clearance between waterline and wetdeck?
    I try to search information on www.
    I find following simple formula.
    a. DNV rule. HL=0.22*Lwl*(0.3-0.0008*Lwl)
    b. documents from THE SECOND CHESAPEAKE POWER BOAT SYMPOSIUM.
    Ⅰ、Displacement catamarans : t=(0.045…0.060)L
    Ⅱ、Planning catamarans: t=(0.02…0.03)L
  2. jorgepease
    jorgepease Senior Member
    Sailing?
    Everyone always says don't compromise bridgedeck clearance but I see some big names at around 30" while other performance cats above 47" regardless of length.
  3. goodwilltoall
    Likes: 26, Points: 28, Legacy Rep: 31
    goodwilltoall Senior Member
    Min. 1'-0" clearance (no obtructions) for every 10'-0" Beam OA.
    fallguy likes this.
  4. JSL
    JSL Senior Member
    A guide I got from a well known multihull designer (power and sail) was minimum of
    Disp. hull = 6 1/2% of the DWL (ie: 30' DWL = 1.875')
    Planing hull = 3 1/4% of the DWL
    As a check I looked at a 65' power cat (225 passenger tour boat, semi-disp hull form- cruise 8-10 knots) I did several years ago. Wet deck freeboard was 3.0' on a 60' DWL = 5%. Boat does harbor tours so water is usually calm.
  5. Mr Efficiency
    These formulae are a guide, I suppose, but other factors affecting the calculation would be area of operation, slimness of hulls, vertical taper of hulls, shape of intersection of hulls with the wet deck, and provision of wave breakers. Or at least, I "imagine". :cool:
    dsigned likes this.
  6. JSL
    JSL Senior Member
    Correct
  7. TANSL
    Likes: 960, Points: 123, Legacy Rep: 300
    They are a guide indeed, there is no rule that requires a minimum value of the air gap but, depending on the navigation area, Lwl, ... and the air gap you will have to reinforce more or less the wet deck.
  8. Ad Hoc
    Likes: 2,001, Points: 113, Legacy Rep: 2488
    Depends on the type of catamaran, its duty, role, location of operations, what is it: yacht, passenger, crew boat, fast ferry, and of course sea conditions...etc etc
  9. Ajmal Cosman
    Ajmal Cosman student
    Can someone please accurately define the Air Gap with some reference please?
  10. Ajmal Cosman
    Hi Tansl you are very knowledgeable about catamaran can you please help me for i need a reference and a good definition of the air gap ?
  11. TANSL
  12. garydierking
    Likes: 73, Points: 28, Legacy Rep: 174
    garydierking Senior Member
    If you can't row your dinghy under it, don't go to sea in it.
    dsigned and Doug Lord like this.
  13. Mr Efficiency
    Limbo rowing ?
  14. Alik
    Likes: 388, Points: 93, Legacy Rep: 1306
    Alik Senior Member
    Min values are, for power cats:
    - displacement 4-6% of length
    - planing 2-3% of length
    These values are for middle, need rise at bow at fwd 25% of wet deck
    The values above are minimum, higher values are recommended
    Another consideration: 1/2 of anticipated operational wave height, for middle section.
    For sailing cats, obviously 'as much as possible', however high clearance will result excessive windage. I would say 800-1000mm for 40', up to 1200mm for 60' cat is good reference.
    My paper on power catamaran design, available from RINA:
    Nazarov A. SMALL CATAMARANS: DESIGN APPROACHES AND CASE STUDIES//Trans RINA, Vol 157, Part B1, Intl J Small Craft Tech, Jan-Jun 2015
    Doug Lord likes this.
  15. tom28571
    tom28571 Senior Member
    I don't know what the formula should be but do know that if you get it wrong, you're in for a lifetime of misery.
