Catamaran
Discussion in 'Boat Design' started by Iinvent1963, Nov 6, 2015.
  1. Iinvent1963
    Iinvent1963 Junior Member
    Morning
    I'm not sure if I'm in the right area or not ( my first day on here ) ,but I've been trying to find a Center console cat design with very little luck.
    Does anyone know we're I can find a fiberglass design ?
    Hope some has got something or at least point me in the right direction.
  2. Mr Efficiency
    You should specify size, number of engines you want, symmetrical or asymmetrical hulls, open or enclosed waters etc.
  3. Iinvent1963
    Good point thank you
    I'm looking too build in the area of 21' too 24' open center console fishing boat .And I a some it would have to be twin motors although a single would great if that's possible
  4. gonzo
    Is this a one-off or are you planning on production?
  5. Iinvent1963
    It's a one off for my self too use
  6. gonzo
    Do you want a cored hull or solid fiberglass? For a solid fiberglass, you will need to build a plug and take a mold; then make the boat. Basically, you build a boat three times. With foam or other core, you build a set of frames/molds, lay the core over and laminate the outside. Then you turn it over and laminate the inside. There will be a lot of fairing and sanding, which takes about 80% of the total labor for a really nice finish.
  7. Iinvent1963
    So which would you recommend is better and do you know of any designs out there
  8. Mr Efficiency
    As gonzo points out, fibreglass is not ideal for one-off boats. You should be able to find designs for alloy or plywood construction. Here's an example using alloy:
    http://www.platealloy.com/cats.htm
  9. gonzo
    That would be my choice too. With plywood, you can incorporate some cold molded sections to create compound curves if necessary.
  10. TANSL
    Likes: 414, Points: 93, Legacy Rep: 300
    To the extent of my ability, I will try to help Iinvent1963 :
    In addition to explaining the construction method that each of us would use, and Iinvent1963 has not asked, "does anyone know where he can find a fiberglass design?". I do not know, if I did gladly say.
    I guess, once known design in particular, we can talk about the best construction system, not before.
  11. Mr Efficiency
  12. Richard Woods
    Richard Woods Woods Designs
  13. Iinvent1963
    I would deff go with plywood as I have done a couple of small boats with plywood.
    I'm sorry I didn't make that clear that is the way I do want to go .
    Like I said I'm New at this and am looking for a nice modern design
  14. Tanton
    Likes: 92, Points: 38, Legacy Rep: 294
    Tanton Senior Member
    C-C Power Catamaran.
    There is the " Flat Cat".
  15. Alik
    Likes: 279, Points: 93, Legacy Rep: 1306
    Alik Senior Member
    This one is 6m.
    Composite is ideal for one-off vessels - we deigned dozens of boats in sandwich panels (say, honeycomb panels with fiberglass skins), they are fast to assemble, stiff, light and do not rot/corrode.
