Catalyst question
Discussion in 'Materials' started by kapnD, Oct 28, 2024.
  1. kapnD
    Likes: 567, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    I’m hand laying vinylester resin/fiberglass weave over a plywood hardtop ,there’s lots of details on the inside that slow the process down, and creating more cold joints than I want to deal with.
    I’ve heard rumors about a slow settting catalyst, but my local supplier doesn’t seem to know about it.
    It would sure be nice to have more time to gel, it’s always hot here, mix goes off quickly even at 1%.
    Anyone know of such a product?
  2. wet feet
    Likes: 627, Points: 113, Legacy Rep: 124
    wet feet Senior Member
  3. fallguy
    Likes: 1,999, Points: 123, Legacy Rep: 10
  4. gonzo
    Likes: 2,341, Points: 123, Legacy Rep: 2031
    Are you using waxed resin? Usually, if they are air inhibited the surface will stay tacky for a long time.
  5. ondarvr
    Likes: 728, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    There are blends of various ratios.
    MCP75 is common, so is Straight CHP. You can get some CHP and blend it with your current catalyst at any ratio you want to get the desired result.
  6. kapnD
    kapnD Senior Member
    Thanks for the input and links.
    I’m making progress now that I’m armed with some knowledge.
  7. KD8NPB
    Likes: 40, Points: 28
    KD8NPB Senior Member
    popular choices;
    Nouryon Trigonox 263
    Arkema Luperox CAT730
    United Norox MCP75
    They're all MEKP / CHP blends.
  8. starcmr
    Likes: 9, Points: 8
    starcmr Junior Member
    Yes, slow-setting catalysts are available for vinylester resin, which can help extend your working time. These catalysts are designed to slow down the curing process, giving you more time to work with the resin, especially in hot climates. Some suppliers may not carry them as standard, but you could try looking for a "slow cure" or "extended working time" catalyst from specialty suppliers or check with larger distributors who focus on marine or composite materials. You can also experiment with temperature control (cooling the resin or workspace) to slow curing.
