Cat sailing rig on small wooden boat
mizana
New Member
Joined
Nov 13, 2016
Messages
Reaction score
Location
marmaris
hi, i have 4.5 mt wooden boat she is abaut 300 kg, i like to put cat sail rigon her can any one give idea if the cat sail good up to wind, or what king of sail will be good up to wind.
Welcome to the forum.
The cat rig does very well to windward, if it has reasonable aspect ratio, good trim and is well arranged. That's pretty heavy for such as small boat.
thank you for your reply and the information, my boat is 4.50 leght and 1.70 beam
my boat
this is her picture
Hi PAR, the boat has an existing long and moderated deep keel, so maybe he could try first if the existing keel beam offers sufficient leeway resistance already, instead of mounting a central appendage (dagger, center or leeboard) right away . . ? ?
See the thread: Small Wooden Boat Sail - (without the full deck)
click pics to enlarge
See post #3 of the linked thread for the draft:
. . . . she is 450 cm leght , 170 cm beam, 50 cm draft, empty weight is abaut 250 kilograms. . . . .
Maybe, but windward progress will not be terribly impressive with that very shoal, low aspect keel. I also suspect it'll be pretty tender, given her sections, in spite of her mass.
what do you think abaut lateen sail on her, do you think lateen will do better.
I'll quote from your post #4 of the previous thread, see the comments + links below the pictures...
The above picture shows a Leg of Mutton Sail (aka: Leg o’ Mutton / LOM / Mutton / 3 sided sprit)
The two above pictures show a Lateen sail, Lateens however are cumbersome to reef and tack . . :idea:
Nice pictures though ! - :) - - - (quote is from the last link)
