Cat draft
Discussion in 'Boat Design' started by Saqa, Dec 28, 2014.
  1. groper
    groper Senior Member
    The software is leading you up the garden path. A single hull displacement at given draft = 1000lb. Then 2 identical hulls at same draft will give you 2000lb.
    If you can't figure out the software settings, just work that part manually and use the software for it's other functions. Or use better software...
  2. waikikin
    waikikin Senior Member
    Not trying to lead you down the Luddite path but I'd tend to do preliminary stuff on graph paper with a pencil using the grid as a metric representative of a decimetre... every 100mm box equals a liter, you can apply a multiplier(x 1.025) for salt water but hardly worth it, for volumes use trapezoidal rule as cats are pretty straight- it just averages your end areas from station to station- for these you can count the squares & part squares on the paper- say 0.25, 0.5, 0.75. Just feels tangible & real to me.
    Jeff.
  3. Timothy
    Likes: 15, Points: 18, Legacy Rep: 202
    Timothy Senior Member
    In some 3D software if you mirror an object it will measure as a negative of the other part . If this part is a component of other parts in a complete model then the volume calculations will be wrong.
  4. Saqa
    Likes: 15, Points: 18, Legacy Rep: 75
    Saqa Senior Member
    I have come to the understanding that if just the single hull sits fine then if I pair it I wont get any worse draft in the real world
    I have started another thread
    http://www.boatdesign.net/forums/boat-design/cat-draft-2-a-52182.html
    Here I have drawn identical single and paired and posted screen shots as well as cad files. I will appreciate it if you guys could take a gander and see if I am missing something about cat mode or looking at a bug. I will also forward that link to the software developer, maybe its a bug they haven't caught
