Carlson Hull Designer Alternatives?
Discussion in 'Software' started by Ted Grant, Feb 2, 2025.
  1. Ted Grant
    Ted Grant New Member
    After years away, I want to design some small boats.
    I LOVED the free "Hull Designer" from Carlson Design. It was just right for my purposes: designing small stich-and-glue ply boats. I loved how you could print patterns for layout on plywood. Or, as I often did, print on cardstock, cut and tape to make models.
    However, I find it hard to use now. Probably because it has not been updated in years.
    Can't blame Carlson-- he did a great service to making available, and there's no money in it, so why would he do the PITA work of updating it?
    So... Anyone aware of:
    a) Guides or workarounds to make it easier to use?
    b) Good alternative programs?
    - Does at least what Hull Designer does
    - Free or low cost for an amateur home designer
    - Minimal learning curve
    Any advice much appreciated!
    Ted
    PS- Maybe I just need a 2014 computer
  2. skaraborgcraft
    Likes: 276, Points: 63
    skaraborgcraft Senior Member
    If you find that difficult to use, i dont know of any new program that is any more basic. If only for small craft.....
    Bearboat Software
  3. skaraborgcraft
    I have not found an active link for "hullform", that was pretty basic but worked fine.
  4. Ted Grant
    Thank you!
  5. Dolfiman
    Likes: 709, Points: 113
    Dolfiman Senior Member
  6. greenish
    greenish Junior Member
    I really like this software too, despite many more advanced options I come back to it when I want to play with an idea. Just so straightforward and tangible. I have gotten it to run pretty well on Windows 11, even got the table of offsets window back, by playing with the compatibility settings.
    That said, I too would like a more modern interface and a few more options... but not much more than that. I've also found (only a few) errors, mostly related to the way it calculates displacement for odd shapes.
    I keep playing with the idea of trying to re-write it - I haven't done an application before but have been learning various pieces of the puzzle for other purposes. Do you suppose there would be wider interest?
  7. greenish
    Actually looking back I think the main thing that allowed it to work on Windows 10/11 was to copy the three .OCX files from the HUL folder to the C:\Windows\SysWOW64 folder: MSCOMCTL.OCX, DBGRID32.OCX, and Msflxgrd.ocx .
  8. skaraborgcraft
    People have to start somewhere, Freeship with its gazzilion buttons is off-putting from the get go. The real question is, why these simple programmes are no longer availiable, is it just software compatibility? I did run my old Plyboats 2.0 in a virtual windows.
  9. droussel
    droussel Junior Member
    I was a developper for over 20 years and am also interested in learning how to design smaller sailboats. I just finished building my Michalak Mayfly 16 this summer and thought it would be fun to learn more about the design aspect. Reading on Jim's old blog, I saw he was using Carlson Hulls, but it isn't maintained anymore and I have a MacBook...
    I'd know how to make such a program and if I was to do so, I'd do it in javascript, so it could run on everyone's computer, probably make it MIT licensed and put the code on github so anyone can contribute. Only thing is, I know how to code but I am unsure what the algorithms are behind those software. If someone knows and is willing to share a description I'd be happy to give it a go after the summer months.
  10. Dolfiman
  11. greenish
    I'd definitely be interested to help with this; I have already made a (rough) outline and understand the key naval architecture algorithms from a moderate to high level. I've also played with mocking up different parts of it in python/java/octave (matlab). Have worked with software folks before but never as a developer myself.
  12. droussel
    That could be a pretty interesting collaboration. I won' have much time until about end of august, but by then I should have time to dedicate to this project. Until then, maybe we could start by documenting the app "requirement"? What features it should have, how those work, etc.
    greenish likes this.
  13. wescraft
    wescraft powder monkey
    Greenish, so the .ocx files you took out of the carlson folder and then copied into the windows\syswow64 folder?
    I got a new windows 11 computer and haven't been able to make this work yet...
  14. greenish
    Yes, I think that's correct.
  15. wescraft
    Greenish, you gave me the answer I've been looking for. That worked. Thanks for that! By the way, just another reason I hate Microsoft....
