Carbon Fiber boarding ladder....
Discussion in 'Fiberglass and Composite Boat Building' started by paxfish, Dec 17, 2014.
  1. paxfish
    paxfish Junior Member
    Hi Gang,
    I'd like to build a lightweight boarding ladder that will be permanently mounted between the forward tramps on my 28' cat. The intended use is general boarding near the shoreline, but I expect it to be quickly deployable to use in a M.O.B situation.
    Meaning, I uncleat a line and the forward end of the ladder drops to 45 degrees supported by a dyneema line on the forward crossbeam.
    I have modest fiberglass experience, and would like to make this my first foray into carbon fiber, for the simple reason that I want very little weight on the bow of the boat. Where can I find info suggesting a specific layup schedule over foam core for this project?
  2. upchurchmr
    upchurchmr Senior Member
    From a Naval Architect - if he deals in carbon.
  3. TeddyDiver
    Likes: 150, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    Hmmm.. Floating boarding ladder, maybe you need a handy billy to get it down.
  4. paxfish
    Nah - I think the weight of the crew will push it down when needed, and since it floats, it won't dig into the bottom near shore.
    Remarkably, after googling, I find there are companies making carbon "tactical ladders" for law enforcement. An 8 footer weighs about 6 pounds! Prolly costs $1000 though, so I will make it myself.
  5. lenm
    Likes: 3, Points: 3, Legacy Rep: 10
    lenm Junior Member
    What about getting some light weight carbon fibre windsurfer masts to use as the tube stock.
    A racing mast can weigh under 2kg. The cheaper ones should be had new for $200. They are 4m long.They are prepreg carbon construction on a mandrel and you simply won't be able to build tubing as light,strong, and have the finish of these.
    I have used broken ones for everything from fish tag poles to support struts, outrigger bases.
    Someone may be able to suggest a good method of fusing the tube together into ladder (maybe carbon rail tape?). I'm considering using some to build the support structure for the hardtop on a boat I am building soon.
  6. paxfish
    good thinkin!
    1. LP
    2. CloudDiver
    3. sailsherpa
    4. schakalen
    5. mberry
    6. andy47
    7. jorgepease
    8. svquintana
    9. arzzeee
    10. grady
