Carbon beam
Discussion in 'Fiberglass and Composite Boat Building' started by fallguy, Sep 30, 2022.
  1. fallguy
    Likes: 1,505, Points: 123, Legacy Rep: 10
    fallguy Senior Member
    Thanks for continuing to contribute here. Most of this is my own fault. I shifted some weights too far forward, overbuilt the salon, etc, the boat, on balance is a dream.
    I even used king starboard for the cabinet frames and the crap is awful heavy and doesn't really look that good.
  2. Ad Hoc
    Likes: 1,440, Points: 113, Legacy Rep: 2488
    Without seeing a view from aft looking fwd - on the transom - it would be just speculation.
  3. Heimfried
    Likes: 129, Points: 43, Legacy Rep: 37
    Heimfried Senior Member
    Hi Dan,
    if you are still interested in building a carbon beam, the couple I mentioned above would be ok with direct contact.
  4. fallguy
    The jackplate company said the water parts the transom and is coming up and deflecting up.
    interceptors or a plate to close off the jack space
    leaning toward stainless interceptors, but the boat has rocker, so the transom angle would be hard into the flow like a brake unless it has some angle...how much then???
  5. redreuben
    Likes: 214, Points: 63, Legacy Rep: 349
    redreuben redreuben
    Shower; hard to see from the angle but it does appear to be coming from under the transoms so my guess is it’s a consequence of the bow down trim.
    Well, we are going to be working to fix that this winter, so maybe one thing at a time, but fixing it later would require pulling the boat..
    it only happens above 2500 rpm
  7. fallguy
    Unfortunately, my German is nicht sehr gut und I need someone to help me spec the laminate.
    Is there anyway to spec a carbon laminate based on an aluminum counterpart?
    My aluminum is 6061 or 6063 and 4.5 od and 1/4" thick which a major overkill.
    I'd even pay for a schedule.
  8. redreuben
    redreuben redreuben
    fallguy likes this.
  9. fallguy
    I am going to put this on pause. It seems daunting at 12 feet long. Even a local filament winding company only makes 8 footers and they charge $2000.
    The only way I see to do it in carbon tube is using infusion which is too new for me to risk on such a big part.
  10. redreuben
    redreuben redreuben
    Rob Denny uses Etamax engineering. I know it’s wrong continent but should be a reasonable price guide.
  1. steve lewis
  2. fallguy
  3. LP
  4. ahender
  5. Stingrig
  6. J.Byl
  7. GrahamR
  8. polarhiker
  9. fallguy
  10. CloudDiver
