Canopy frame material, aluminium or stainless steel ?
Discussion in 'Powerboats' started by hyboats, Sep 10, 2010.
  1. hyboats
    hyboats Junior Member
    I am chosing canopy frame for my boat, some one said aluminium is better, it is light and lower cost, some others said stainless steel is more shining and beautiful. :?: :?:
    confusing
  2. hoytedow
    Likes: 373, Points: 93, Legacy Rep: 2489
    Both are true. I would use aluminum.
  3. apex1
    apex1 Guest
    Beauty lies in the eye of the beerholder, no doubt. But it will be easier to get it already done to fit that boat in SS, than to design and weld it in AL.
  4. alan white
    Likes: 122, Points: 0, Legacy Rep: 1404
    alan white Senior Member
    Stainless, because the tubing cost is but a small part of the overall cost. And stainless is hands down the better material, looking new for many years. Fasteners for either material are generally stainless, which matches the stainless tubing galvanically.
  5. hoytedow
    I sit corrected.
  6. tom28571
    tom28571 Senior Member
    In the T top, which one do you want to grab hold of to keep from going overboard? Stainless, hands down. All that gear attached to the T top will be much more secure on a stronger frame. I recently had to rebuild part of a bimini that is made with aluminum tubing. It was damaged in contact with a piling. Stainless would probably have just been bent a bit and required only straightening.
  7. Bglad
    Likes: 5, Points: 18, Legacy Rep: 67
    Bglad Senior Member
    All the comments about stainless are true but I can't remeber when I last saw it used on a boat like the one in the OPs original message or any other.
  8. mydauphin
    mydauphin Senior Member
    All above is true, but if you price the labor and materials you might find Aluminum a lot cheaper and as good if you have it anodized. You have to get someone that really knows what they are doing either way. The quality is in the workmanship. I have seem cheap ones and they look cheap, and well built ones that look like works of art, both in AL and SS.
  9. apex1
    apex1 Guest
    I cannot remember when I have seen anything else but SS on such application.
  10. mydauphin
    There seems to be a geographical difference going on... In South Florida, AL is most common in Boats under 30'.
    May be you guys are confusing Anodize Aluminum for Stainless Steel. Check out http://www.atlantictowers.com/at_sub/faq.html
  11. yipster
    yipster designer
    when canvas and frame should fold the accesoires and hinges are important
    i see they also come in alu so can be an anodised but would the little screws still work
    ss railings too is expensive stuff and i've been wondering on the subject before
  12. mydauphin
    The Aluminum is bent and welded as needed. Stainless steel is much harder and will give rust streaks at welds over time. Either one can crack if not done right. The guy that does welding for me and Atlantic mention link above make beautiful welds and can even make them invisible.
  13. apex1
    apex1 Guest
    That might well be the case. Sometimes we tend to see the world from our armchair only.
  14. alan white
    Stainless is what lifeline stanchions are made from in almost every case, no matter where the boat was built.
    Rust should not be a problem on any well-polished weld as long as the welding rod is correct and the pipe is correct (316 stainless, e.g.).
    Simply compare to existing similar stainless parts such as the stanchions mentioned, or bow and stern pulpits.
    Over time, given enough salt water exposure, any stainless will need to be repolished. Yet, it's only the surface that requires the maintainance and it isn't much work.
    I've seen anodized aluminum with a few years on it (spars) and refreshing the surface back to original is impossible or at least prohibitively expensive.
    It has to be painted, normally with two-part paint.
  15. CDK
    CDK retired engineer
    If you use aluminum with stainless fasteners you might as well put it together with rivets because after a few months at sea you cannot take it apart anymore.
    As Alan White says in post #4, the price of stainless tubing is only a small part of the total costs.
    The best polished stainless parts on my boat is the 25 years old canopy frame. The fabric and the wind caress it every day.
  1. smilicus
