fallguy
Boat Builder
- Joined
- Dec 7, 2016
- Posts
- 9,037
- Reaction score
- 2,119
- Location
- usa
Fallguy. De-mold time is 36 hours. I can't find a retailer. That probably means I can't afford it.
see if Noah's has an infusion recommend
Note: This feature may not be available in some browsers.
You might hit up @rob denneyI previously looked at Noah's.
I'll be buying from Easy Composites. There is a hazard fee so I'll buy more than I need for now.
{{model.productMeta.WebStoreDisplayName}} https://www.easycomposites.co.uk/#!/resin-gel-silicone-adhesive/epoxy-resin/epoxy-infusion-resin.html
The slow hardener has a 80-100 minute gel time, 2o0-450 cps viscosity. Not sure why the range is so great. I will ask why this is.
Of all the composite websites I have visited, Easy Composites is the most organized and they also have a forum.
Customer support has been fast in answering questions.
He uses an infusion epoxy mixed in AU thats 11USD a kg. But thats a bulk price. He will know the best infusion epoxy in the UK.
Also has good advice on how to set up infusions and loves to chat boats.
I just helped with infusion for a 36' boat yesterday.
We use VE/DCPD blend resin, infusion specific with about 150 CPS viscosity. Gel time is about 60 minutes with MEKP9.
Branch spacing is 24 inches average.
Branches a premade, supplied by VECTORPLY corporation. They're basically pre-stitched peel ply with enkafusion or split tubing.
The entire perimeter is surrounded by vectorply red infusion media. It's a long tail of peel-ply with split tubing. The split tubing is pulled up in to the bag, and only the tail of peel ply touches the mold. Vacuum passes through the peel ply easily, resin does that. This helps slow the resin flow once it gets to the vacuum zone, that way you're not sucking a ton of resin in to your catchpot if your branch spacing is poor.
The keymost factor to success is the material we mainly use is either QXCFM3515 or QXCFM5615.
These are quadraxial e-glass (0/90/+45/-45) with continuous filament matting stitched on. Continuous filament is not to be confused with chop strand...it flows VERY well for infusion and adds thickness, but not much strength. Thickness is good for stiffness. Stiffness and tensile strength work together.
For that resin and infusion, you might try MEKP925H.
It will foam less, plus the viscosity increase will be delayed until until later in the cure profile. This can speed up the infusion.
HDP75 might even work better depending on part thickness, and will result in less shrink.
