Can you seal a wood boat with liquid rubber
Discussion in 'Wooden Boat Building and Restoration' started by Person named james, Apr 7, 2023.
Can you use liquid rubber to seal a wood boat like how you would use fiberglass
  1. Yes
    0 vote(s)
    0.0%
  2. No
    3 vote(s)
    100.0%
  1. Person named james
    Person named james New Member
    I am looking into making a 13 foot wood plywood boat an wanted to know if you could seal it with something like flex seal rubber paint I've previously used it to seal riveting on an aluminum boat an wanted to know if it would work as a water proof coating for a wood boat weather than fiberglass and resin
  2. rwatson
    rwatson Senior Member
    The bond between rubber paint and wood is not very strong.
    It might work for horizontal areas, that don't get much wear, but based on my experience, you would end up with moisture getting in, and causing wood rot, as the wood "moves".
    I have used the rubber paint on canvas for waterproofing, but it broke up quickly from the continual flexing, as it has no inherent strength.
    You would get a better result with an asphalt/bituminous mix. That doesn't make a great surface to walk on, or touch, as it tends to stay sticky for a long time, but the waterproofing seal is a lot better, and it has more immunity from flexing.
    Of course, there is nothing wrong with good ol' quality undercoat and exterior grade paint. That is especially true for boats that are not left outdoors for a long time.
  3. skaraborgcraft
    Likes: 261, Points: 63
    skaraborgcraft Senior Member
    Chlorinated rubber paint has been used on plywood. Thin the first coat with xylene and let it gas off, subsequent coats will bond well. It is a "soft" coating, so can smudge on impact rather than fracture like a neat epoxy coating. Stinks to high heaven in application, but less messy than anything bitumen based.
  4. rwatson
    Hmm, the question was about "liquid rubber". From what I can see, chlorinated rubber is a totally different animal.
  5. Barry
    Likes: 624, Points: 113, Legacy Rep: 158
    Barry Senior Member
    While Xylene may be a thinner for chlorinated rubber paint and other coating applications, it can be extremely harmful to use.
    Reprinted comments below CDC
    Xylene (C8H10) is a colorless, flammable liquid with a sweet odor. Exposure to xylene can irritate the eyes, nose, skin, and throat. Xylene can also cause headaches, dizziness, confusion, loss of muscle coordination, and in high doses, death. Workers may be harmed from exposure to xylene. The level of exposure depends upon the dose, duration, and work being done.
    A link to the CDC notes on it. And check out the Safety Hierarchy link
    Xylene | NIOSH | CDC https://www.cdc.gov/niosh/topics/xylene/default.html
    For those that are interested
    3M markets specific types of filter respirators for different VOC and other gasses. They have a table that you can look up what your are going to use and then give the applicable cartridge.
    BUT while these cartridges can reduce the amount inhaled, they can allow some vapor to get through. I had been in a shop many years ago where a newbie was going to spray a diisocyanate polyurethane liquid and was using a welders filtration cartridge as a mask. My point is to match the type of vapor to the cartridge as compared to picking out a cartridge from say a Home Depot.
    You might consider having it sprayed with either a polyurethane or polyurea pick up truck box liner as both of these products have an extremely high PLI (pounds per lineal inch) rating. ( a release/adhesion property) Additionally, they offer high abrasion and high strength. Home Depot and other automotive stores also sell a single or two component poly-xxxx (not sure which one) coating that you can paint on. Truck Box line coating.
    Again watch the mask matching and work outdoors
    The problem with any coating that completely seals all sides etc of wood, is that any moisture trapped inside can cause rot issues with the wood. If you encapsulate the wood and then run a screw through it
    to hold a cleat etc, and permit water inside, the water can create rot. For the cost etc. Watson's comment, a good undercoat and overcoat
    has kept many a boat floating for decades.
  6. skaraborgcraft
    Not wishing to be picky, but chlorinated rubber is a liquid. Sounds like "liquid rubber" is a trade name for something in the US. I am merely pointing out what is known to work.
  7. rwatson
    Sure, that makes sense
    Where I live, liquid rubber is s trade name for stuff that looks like a wetsuit when it's cured.
    Chlorinated Rubber features as a paint component in things like anti fouling finish, deck paint and a dozen other products.
    Sounds like we need to get the op to be more concise.
  8. messabout
    Likes: 591, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    In the U.S. a highly advertised rubbery gunk is named FlexSeal. It works in some situations but perhaps not all the ones that the advertiser claim.
    Why would you want to use that stuff or its equivalent on a boat? A plywood boat will be very happy with some epoxy, which will cost less, be much easier to apply smoothly, and make a nicer finish than rubber.
    rwatson and Barry like this.
  9. sdowney717
    Likes: 115, Points: 73, Legacy Rep: 274
    sdowney717 Senior Member
    Use loctite pl premium polyurethane construction adhesive. Mix in some sawdust to seal all holes and seams. Skim coat couple coats on whole hull using a wide knife. I know this works well as I sealed all the seams on my 37 eggharbor
  10. sdowney717
    And pl takes paint well.
  1. tom12910
  2. bubblehead620
  3. reelpleasure
  4. aaronhl
  5. tinpin4544
  6. Yellowjacket
  7. sdowney717
  8. sdowney717
  9. sdowney717
  10. IwoodifIcould
