Can butter be a release agent for epoxy?
Discussion in 'Fiberglass and Composite Boat Building' started by Robert Biegler, Aug 24, 2021.
  1. Robert Biegler
    Likes: 118, Points: 53
    Robert Biegler Senior Member
    I want to glass the inside of a plywood mast partner, using epoxy resin. I want the inside to be quite smooth. I thought I could inflate a balloon to press the glass to the inside of the partner and get a smooth surface, but I expect the rubber would stick to epoxy. I don't see how I could use wax as a release agent, because I don't think it would expand with the balloon. Then I thought of butter. At room temperature, it should be soft enough. Is it likely to work as a release agent? Would it interfere with the epoxy setting?
  2. Blueknarr
    Likes: 461, Points: 83
    Blueknarr Senior Member
    Butter would work.
    So would wax.
    So would no release agent.
    The epoxy won't stick to the balloon.
    DogCavalry likes this.
  3. Kayakmarathon
    Likes: 49, Points: 28, Legacy Rep: 10
    Kayakmarathon Senior Member
    Butter might attract termites or other things that might like to live in that cavity.
  4. Will Gilmore
    Likes: 531, Points: 113
    Will Gilmore Senior Member
    I worked as the mold builder for an architectural concrete company in Sarasota. I coated the molds with epoxy resin and they used vegetable oil to release the concrete from the molds.
  5. Milehog
    Likes: 179, Points: 43, Legacy Rep: 215
    Milehog Clever Quip
    Last Tango In Paris?
  6. upchurchmr
    upchurchmr Senior Member
    Try it and show us the mess.
  7. Robert Biegler
    True. I tried. Thank you.
    Will Gilmore likes this.
  1. mrdebian
  2. cando2
  3. itchyglass
  4. mrdebian
  5. mrdebian
  6. Gasdok
  7. bedfordd
  8. fly186
  9. seby
  10. aaronhl
