Can blue board be glassed with polyester resin?
Discussion in 'Fiberglass and Composite Boat Building' started by therigwelder, Feb 13, 2012.
  1. therigwelder
    therigwelder Junior Member
    Can blue board be glassed with poly?
  2. lewisboats
    Likes: 128, Points: 0, Legacy Rep: 1603
    lewisboats Obsessed Member
    I am assuming you are talking about extruded poly styrene from Home Dumpo or Lowe-st...no. Polyester will melt the styrene into goo. You would have to use epoxy for that.
  3. ondarvr
    Likes: 373, Points: 83, Legacy Rep: 506
    ondarvr Senior Member
    There are some polyesters that will work, but you need to special order it.
  4. lewisboats
    I would expect that they would cost close to the same as epoxy so I don't see the benefit.
  5. tropicalbuilder
    Likes: 3, Points: 0, Legacy Rep: 38
    tropicalbuilder Junior Member
    i've been able to use poly over styrofoam priming the styrofoam with white glue.
    The vinil based white glue used by carpenters for wood.
    As my foam was white i put some black pigment in the glue so to be able to see any void while painting.
    I also found that it is better to prime with one coat of resin, let it set and then go on with the laminations.
  6. Herman
    Herman Senior Member
    You can apply a layer of the special polyester, and after cure laminate further with normal polyester. That is the benefit.
  7. ondarvr
    Correct, and the cost is less than epoxy.
  1. Bullshipper
  2. a.suardi
  3. fallguy
  4. Toepfer Marine
  5. Scuff
  6. DogCavalry
  7. Tom Hickson
  8. brokensheer
  9. ziper1221
  10. Racman
