Calculating Transver BM of a catamaran
Discussion in 'Stability' started by Grimorum, Mar 15, 2016.
  1. Grimorum
    Grimorum Junior Member
    Hi All,
    I am a beginner in studying naval arch.
    Encountered a problem as follow and I cant seem to solve it.
    Each of the two hulls of a catamaran has the following dimensions
    Ord. No. 1 2 3 4 5 5.5 6
    1/2 Ord(CM) 0 4 6.2 7.2 6.4 4.9 0
    Length of each hull = 18m
    Displacement each hull = 5.3meter cube
    Ordinates are spaced evenly.
    the hull center lines are 6m apart.
    What is the transver BM of the boat?
    I convert all dimensions to meter, then using Simpson first rule to calculate the y cube. Then using the formula: (1/3)integrate y cube dx and with the excel sheet, using this transverse second moment of area and divide it by the volume of displacement.
    The answer I get is very far from the answer of 3.12m.
    Hope someone can enlighten me in this question and best would be list out your steps.
  2. RAraujo
    Likes: 38, Points: 28, Legacy Rep: 114
    RAraujo Senior Member - Naval Architect
    Are you taking into consideration that you have 2 hulls and also the added transfer second moment of area due to the fact that each hull is 3m apart from CL?
  3. Grimorum
    RAraujo, very much appreciated, you just rang a bell in my head with that transfer second moment of area with the parallel axis theorem. totally forgotten about that. Got the answer now.
  4. TANSL
    Likes: 949, Points: 123, Legacy Rep: 300
  5. Grimorum
    BM in my case is the Center of buoyancy to the metacenter.
  6. TANSL
    Oops, sorry for my stupid mistake. I should have read your post more carefully.
