Calculate area from moses
Discussion in 'Stability' started by mactavish, Jan 22, 2023.
  1. mactavish
    mactavish Junior Member
    Hi,
    I would like to determine how to calculate the area in the attached.
    You can see there are two area columns one is for righting and one is for heeling.
    I've tried using Simpson but I can't seem to reverse engineer the formula of the area.
    Please see attached file for your reference.
    I have attached as well the graph. I would like to determine the formula for the area.
    Thank you in advance,
  2. mc_rash
    Likes: 69, Points: 28
    mc_rash Senior Member
    What was your result? I assume you didn't use Simpson properly, I got a difference of ~0.08 % and if proper done you also should get reasonable results.
    f(x)*dx ~ h/3*[f(x0)+4f(x1)+2f(x2)+...+4f(xn-1)+f(xn)]
    fallguy likes this.
  3. mactavish
    Hi Mate,
    Can I see your result. I dunno what im missing. Would be glad if you could share an excel or show a bit calculations?
    Thank you,
  4. mactavish
    i tried but im getting wrong values
    SM x gz = fa but my fa does not tally the one from moses...
    I'm trying to get it by degrees
  5. mactavish
    Got it, i was multiplying it to radians silly me. hence im getting the wrong answer.
    i posted the 20.24 area in 12 degrees...
    Thanks mc
    fallguy likes this.
    1. sun
    2. sun
    3. Howlandwoodworks
    4. thinhuk
    5. Floatything
    6. Robert Wilkinson
    7. Anum
    8. Adeyele
    9. Adeyele
    10. Erdem
