Wave loads on cylinder
Discussion in 'Hydrodynamics and Aerodynamics' started by rogerlee, Jul 6, 2015.
  1. rogerlee
    rogerlee New Member
    Place a cylinder at a direction of 45 degrees with
    respect to the x and y axes. Assume it's infinite water depth. How to calculate the wave loads on cylinder?
    P.S.: Since the force expression is nonlinear so we cannot project the velocity in a direction perpendicular to the cylinder axis...right?
  2. DCockey
    DCockey Participant
    Homework or test problem?
    How large is the cylinder compared to the wave height and wave length?
  3. rogerlee
    rogerlee New Member
    thanks for your reply man.
    its just my research interest.
    body dimension is smaller than wave length. so morrison eq can be used.
    i was wondering if horiziontal water particle velocity can be projected to the direction perpendicular to cylinder axis. and integrate? if so, how to intergrate it? thanks.
  1. Goranskoog
  2. Goranskoog
  3. JoshTruman
  4. JoshTruman
  5. sun
  6. Elias1999
  7. zstine
  8. sun
  9. zstine
  10. sun
